Everything posted by Ever Victorious
Ah, finally my stupid Nissan gives me something to apply knowledge to. In my Nissan, our "fault condition" is when the light flashes for 60 seconds then goes solid. When the system goes into a fault condition, the BCM (Body Control Module, another wonderful Nissan POS device) stores a code. Nissan mechanics normally claim that the tire sensor has just lost communication with the system, and they "reregister" (reset) all the sensors to clear the light and get you on your way. However, as we have found out, the error will reoccur after around 1000 miles, and it will always be the same code. We have also found the corrective action: On first failure, replace the wheel sensor for whichever wheel throws the fault code. If the failure occurs again with the same fault code, replace the BCM. Not sure what part of the system on a Subaru takes the part of the BCM. ECU maybe? unless there's a separate systems computer. Hope this helps.
I bought the Loyale
Ever Victorious replied to youareabus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
185's will fit fine. Some models come with them stock. Those particular Kumhos are very similar to a set that came on one of my Kias (2002 Optima LX 4-cyl) that absolutely sucked in the snow. They were, however, very good in the wet, so I can confirm that. sadly, Spokane can get quite a bit of snow, slush, and ice during the winters. I'd suggest a Toyo 800 series touring tire... their dry handling may suck, but their wet/snow handling is great. -
Having been involved in the planning of the first two WCSS shows, I can say that all of the organizers did put in a LOT of work. Even with how small the first two events were (22 cars and what, 96 the second year? no mud pit, etc.), they still took quite a bit of planning. With how complicated it is to throw an event of the size that happened, with all the various aspects of the show and the various vendors... well... Bravo, guys. And I do mean that from the bottom of my heart. While I was not at the show long enough to see any of the troublemakers, I would hope that you either learn your lessons or simply have the grace not to show up again. (and this is not coming from a "minion" of Zap, either. We've butted heads in the past, but he's quite right here...)
Suberdave's Pics
Ever Victorious replied to suberdave's topic in Meet n' Greet. Your USMB Welcome Center
Hey, look, I'm in there somewhere! Nice pics. -
First pics from WCSS8
Ever Victorious replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
I dunno about you, but with how violently my 6 was shaking, I know for sure either myself or the car would have given out FAR before then. One hour was extremely painful, and my friend was kind of shocked that the car didn't break on the way to Schwabbie. -
My friend was taking pictures, hopefully he will email them to me tomorrow. He didn't get all the cars, but quite a few. Was yours the wagon that had the coolant leak early in the day? I'm home now. Getting there was a chore... even after using the hose at the mud pit to wash off mud from the wheels, and spending 20 minutes with a high-power spray washer in town, I couldn't get enough mud out from inside the wheels to get the wheels to balance. Had to drive all the way to Vancouver to find a Les Schwab, so I could drive home at full speed. Note to self for next time: Bring spare set of wheels for mud pit. -
see ya at the show
Ever Victorious replied to monstaru's topic in Meet n' Greet. Your USMB Welcome Center
My dumb arse isn;t pulling out of the driveway for another... uhm... 9 hours. -
The XT6 is now roadable...
Ever Victorious replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cougar... My father attended Shorecrest about that time, I think. Daeron... thanks for the post. And actually, I've been to Alaska before, and you'd be surprised. The summer I went there, it was actually warmer in Anchorage than Seattle. -
1973 Splitgate Wagon
Ever Victorious replied to bryanthompson's topic in Historic Subaru Forum: 50's thru 70's
Never been much of a "woody" guy myself, at least not on imports. Vintage mags might be good... though hard to find. -
I'm also from Shoreline, graduated from Shorecrest in '96. Traffic wasn't really a problem when I was growing up there, but the area has grown so quickly, yet the infrastructure hasn't... -
and considering it was me resurrecting it, 2 months is probably a really short time for completion of that little "project". Thanks to Smart Service, it now drives straight, has power steering, and doesn't overheat. Turns out the thermostat WAS stuck closed. There's a new Failsafe thermostat in there now. The car still runs a LITTLE hot, but not nearly as bad as before. Apparently neither radiator cap will hold pressure, so I need to replace those to finish the cooling fix. But it ran well from Shoreline up to the emissions station in Everett, where I sat around idling for about 20 minutes... passed emissions with flying colors, and drove home just fine. I just put the tabs on it, but it's kinda hot and the A/C doesn't work, so I'm not going to play with it till later this evening.
Sounds like a pretty darn tootin find! Regarding the fuse... I wouldn't think that just one belt motor is attached to a fuse by itself. turn on all the accessories individually and check their function. If you have one that doesn't work, check its fuse. It might be related. If everything else works 100%, it might just be a dead belt motor. If the belt is stuck in the closed/locked position, you can simply use it by detaching the "emergency" buckle every time you get in/out of the car. My friend did this for years with his Peugeot after a belt motor failed and locked the belt in its normal use position.
there are a couple guys here who are absolute regulars at the PaP yards. You might see if one of them can get the parts you need and send them to you for a modest fee, since you're kinda far away from those yards (I go maybe once every 6 months, but I happen to have impeccable timing and a tendancy to enter the yard within an hour of an XT showing up)
I see 'em every now and then in Pull a Part yards. There's also and XT6 for sale on CL right now that would yield the interior parts you need (and other vultures here would want other parts off of it)
$350 sounds like a good bargain for that car. If you don't get it, we'll all be disappointed in you. Give in to peer pressure! It's cool!
The vintage eye popper,eye candy post
Ever Victorious replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
teh hotness makes me drool, yo! -
Gee I wish I had the rest of the car too
I too have never seen the like. Just simply... wow... -
XT6's and temperature
Actually, part of what I felt during the heat test was the fins, in a couple places, and they felt intact. The radiator is cold all over even at full operating temp. I take it that in a normally operating cooling system, the water stays in the engine/coolant reservoir until warm, then the t-stat opens up and sends water to the radiator for cooling? If that's the case, then yeah, it sound like the bad t-stat because the coolant hose coming off of the housing is also stone cold. -
Haven't, yet... I had asked for advice about removing the t-stat housing bolts without breaking the bolts off in the water pipe... the one and only time I replaced an XT thermostat, I ruined the water pipe. -
OK... you guys said run it at operating temp and then check the bottom of the radiator... well, I ran it up to 1/2 to H (what was operating temp on my last XT), and then felt the radiator in several places. I felt it down near the bottom on both sides of the radiator (the tanks?) and also on the fins, then I also touched the top of the fins. The radiator is STONE COLD everywhere I touch it! I take it that's not a good sign?
