Skorzen
Location
Phoenixville
Skorzen's Achievements
Member (2/11)
10
I just got replacement rotors from tire rack for $36 a piece (Brembo). I thought I would mention that the rotors which were installed previous to my getting the car did not have the 8mm holes :-\:mad:. The replacements that I got do though so that should make things a little easier next time. Also a little rant about tire rack, I ordered the satisfied ceramic pads that they had listed for my OBS, but they didn't fit. A little agrivating to find out in the middle of a brake job...
My car isn't sitting evenly so that is why I was looking for springs. Another quick question on struts, I was looking at KYB GR2's and they have two versions, one for cars with ABS and one for cars without. It seems like the bracket for the ABS system is just bolted in place and I can't see the need for a different strut. I wonder about this because I only see one at Subarugenuineparts.com, and also no one has the ABS version in stock. Can someone confirm or deny that I need the ABS version for a car with ABS?
I did search and wasn't able to find anything, actually the search engine would tell me there were no results for terms I knew full well there were (searching for KYB found no results, maybe not enough letters). Thanks for the link, I was actually looking for that specific thread from some others that I did find.
I just noticed yesterday that after sitting overnight when I start my car (97 OBS EJ 22 5 Speed 78K mi) the engin revs higher than normal for a cold engine, and the settles down to where it would normally be. this morning it went to 2.5K and then settled down rather than the normal 1.5 or so that I normally see when I start it cold. So I am wondering if anyone has any idea why it's doing this? It bothers me that this just started, but it also seems somewhat minor, but I would like to know why it's doing this just in case it's not minor. Oh and another note: timing belt, cam and crank seals, oil pump reseal and water pump were all down about 3000 miles ago. Thanks -Will
I put the Falken Ziex 512s on my 97 OBS about 7K ago, and so far no complaints. The only issue is they may be a little loud, but I don't really have anything to compare them too on this car(need new tires when I got it). I thought I would mention that I was able to get sears to match the Discount tire price on these so I go them for about $50 each rather than the $70 sears was asking...
I have been expieriencing the 2000-2500 rpm hesitation issue with my 97 OBS. I have recently replaced the air filter and spark plugs. I noticed the hesitationafter an oil change, but after thinking back I think it may have been occuring before that. I tried resetting the ECU, this worked, but the issue returned after about 20 min of driving. I am thinking that replacing the knock sensor would be the next logical step, but I am looking for input from other people on this. the other thing that I had been thinking was that it could be the "air pocket" in the oil filter, but it's been about 500 mi since the oil change so I would think that would be gone by now with the ECU reset. So what do you think?
