centrino
Everything posted by centrino
There is some way to chack that the timing belt is in good condition? i buy recently a legacy of 1997 2.2, and have 107.000 km. and i don´t know if timing belt is the original or new. in the dealer, don´t know, and i need to know if Timing belt is in good condition, because the change is very expensive (500$) Thanks.
How do you Know exactly what is the problem? my 1997 legacy, have a very little oil leaks, but the engine don´t have a leaks, and steering pump don´t too. transmision maybe the problem. timing belt-oil.... i don´t understand the relation.. What is cam seals and crank seals? oil pump is defective in this years of legacy? Sorry for my ignorance... :-\
I Know that the forester have the traction in 4 weels, and is permanent, 50% in front and 50% in rear AL THE TIME. But in the owners manual of legacy, i read that the AWD isn´t permanent, normally is FWD, and when is neccesary it converts to AWD. I think all subarus have the AWD permanet, and this is the reason for the good results, compare with volvo cross country and similar. (the Outback is better than volvo in hard conditions...) And outback? is like forester or like normal legacy?
Well, connecting the ecu, the problem is "temperature of motor" and "slow motion" that says the mechanic, the mechanic says that it did not remember the code numbers... The mechanic says that it is not connector OBDII in my 1997 legacy, say that it have a special conector for subaru... I do not understand anything... And finally the mechanic says that is not relevant... and i have to pay 30 euros for this.... i am thinking to buy a OBDII. This night i disconnect the batery all night, i hope this resolve my problem...
Hi! i´m from Spain, and i just buy a legacy 2.2 1997, all Ok. But when give me the car, the positive cable of the battery isn´t tighten, and one day later i see this problem, because the car go off... the problem is that the check engine light goes on when i running some miles, and goes off 2-10 minutes later. the engine and car is all ok. Can be a resset problem, or sounds more a MAF problem. Sorry for my english, and regards.
