About ninjaben43
- Birthday 01/28/1980
Contact Methods
Yahoo
ninjaben43
Location
Kingston, wa
Interests
duh
Occupation
free loader!!! i wish
Biography
4x4
Vehicles
'88 gl wag(rig) AA lift,
ninjaben43's Achievements
USMB is life! (4/11)
10
the ej temp sending unit reads half what ea's do(when its reading a quarter temp it is really half, or if its at half- its hot) on the manifold there are two sending units, mtnman38 drilled one out and tapped it to put in a ea sensor. worked great. and adam at nwrs can help with a relay for the fuel pump if you dont have the original. did you get the main relay for the ecu? if you run without it you will have to unplug the battery overnight or the ecu will drain it. awesome build scott.
Motorcyles, what are you riding?
ninjaben43 replied to Slacker's topic in Non Soob Cars and Bikes Discussion
:headbang:1974 jawa cz 175 -
dont need it, but on the other hand, i put in a 81 ps rack and ran lines from my ej pump an it was way worth it. too bad i never really got to enjoy it, i was rearended 268 miles after completion... actually the day i got the ps working.
it is amazing to see a beat up old wagon yhat still has the cargo cover.
i do believe this thread needs to be resurected.....alot has happened in a year...
i need a flippen garage, i think this project may be put away for the winter:mad:
hello mateo:)
Want in from the cold!
ninjaben43 replied to ScoobySchmitty's topic in Meet n' Greet. Your USMB Welcome Center
catch a plane and drive one back, seattle is full o them. good luck. -
Weak Brakes
ninjaben43 replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
test your check valve in the vacuum hose to the master cylender -
pics would help
Diesel motor transplant, 1990 Subaru Loyale Wagon
ninjaben43 replied to TravisD's topic in Subaru Transplants
good luck. a few things to consider: adapter wiring and you are limited on length i dont think even an inline four would fit between the trans and radiator, did vw make a h4 diesel back in the day mabey or is there any such thing as a v4 diesel?
