Manarius
Everything posted by Manarius
Yeah, because in the UK, they drive on the left! RHD cars! I will get a whole army of Legacy guys to tell you that using RHD lights on your car is a bad idea if you want.They blind oncoming drivers because they are AIMED THE WRONG DIRECTION. http://bbs.legacycentral.org/viewtopic.php?t=25838&highlight=jdm+lights http://bbs.legacycentral.org/viewtopic.php?t=16366&highlight=jdm+lights
And I'm sure all the drivers in your area love you at night because you drive around with headlamps aimed the wrong way. Remember, JDM headlights are designed for RHD implementation. There's no amount of aiming that can change the beam pattern. If you want bright lights, try to get your hands on some LHD headlamps from Europe. Europe has stricter (better) light standards than we do.
Bad VLSD?
Manarius replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
VLSD's do wear out eventually. If yours has a lot of miles, I bet it's worn out. -
Subaru SUS?
Manarius replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The SUS is just the Outback Sedan. -
Yes. There should be a shroud put in so that you aren't sucking in warm engine air. Maybe some sort of ram-air intake that sucks in straight from where the grille is? Is there some gain? Well, the car will be louder. Some people say there's gain - I don't know if I necessarily agree with that. I think if there is any, it would be minimal at best. Exhaust work would definitely be needed to make the CAI worth your time.
Can't have my Subaru!?!?
Manarius replied to silverfox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I second what GeneralDisorder said. You don't NEED to have PT4WD. AWD is just as good. -
I think really the only benefit here is the baffle delete that occurred. That is to say, in the stock intake air line, it's not exactly the best curvature or smooth surface. This intake definitely does a better job in that regard. I would much rather to have seen the box be kept, but the metal intake line put in. The stock airbox flows quite nicely and actually gets cold air. This "CAI" actually sucks in hot air from the engine bay...
ericem has proposed that as a solution to vibration at idle while in drive as well. I have gone over this before: When you're holding the car from moving (which you are if you're at a stop light and the car is in drive and you're holding the brake) something has to give in the drivetrain system. The car cannot just absorb all the vibration from the motor trying to move the car and you not letting it do so. Aftermarket axles have absolutely NOTHING to do with this phenomenon as every Subaru with AWD that I've driven has done it - and I know that my SVX has all original axles and it vibrates enough that I can notice it. To the OP: If you pop the car in neutral I bet this vibration goes away? If so, my theory is confirmed on the matter (like it has been on every other Subaru I've driven). You might be able to nail it down to a transmission mount or something, but for something that can be fixed by going into neutral, you might as well do that because it'll cost a lot less.
