Manarius
Everything posted by Manarius
Meh. The SVX suspension is not the same as the Legacy suspension so I doubt any of the parts would fit nicely.
Well, I was in a situation where ABS would have been helpful. Two years ago I slid into a guard rail because my brakes locked up on slush. If I had ABS, I believe I would have been able to at least have avoided the turn rather than cock the wheels and slide straight into the guardrail head on. I like the ABS on my SVX, I wouldn't trade it in for standard.
Pros and Cons of Dual Range VS. AWD ??
Manarius replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't see why not. Snows and AWD is just as good as Dual Range + Snows... -
Repeat thread... In my opinion, a good set of snow tires makes a world of difference. In AWD or 4WD low, the best split you can get 50/50 anyways, so you're not really making any difference. For ease of use, I think AWD is better, but that's for ease. -
I'm thinking that if you just replaced the pads and rotors and then you got a shake, you probably ought to look at the things you just replaced: your pads and rotors. It doesn't really make any sense that a tire just got out of balance. Like someone said above, maybe the rotors got turned incorrectly causing your shaking.
Wiring would be a PITA. At least, as far as I know.
You are right in that the MAF tells the ECU how much air is going in, but ignition is affected by that. Sure, the knock sensor works in there as well, but the MAF, as I see it, is a major player. Why do I see it this way? A year ago my MAF went south on me. When the MAF was failing, all kinds of weird things happened. Things such as bucking, knocking, tapping, engine shaking, etc. If the car's reading too much or too little air coming in, the fuel would be adjusted accordingly and the knock sensor would read a bad mixture as knock and adjust ignition accordingly which would make the car just run like crap. It would probably also knock and tap as well. This is why I wonder if the MAF might be the source of your troubles.
