Manarius
Everything posted by Manarius
First of all, you shouldn't be revving the motor in park. It clearly states not to do this in the owner's manual. What you describe is exactly the same way it worked in my Legacy. The ECU and the engine just can't respond instantly - it just doesn't work that way. Like I've said a million times before, stop trying to find things wrong with your car! There's nothing wrong with it. 19mpg in the city using the A/C (or even not), with AWD and auto is about average. Odds are, you're a teenager so you jackrabbit most starts, and that contributes to your bad gas mileage as well.
Clutch packs or Solenoid C. I'm going to guess that it's probably solenoid C slowly reacting, not the clutchpacks because of the lack of clunk. Either way requires dropping at least the tail part of the transmission for a replacement. If it's worth it to you, you can go that route. For the amount of time/money involved, I'd just deal with it.
Guess what...
Manarius replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You have just 12k more miles than I do. 300 000 kilometers = 186 411.358 miles -
You probably didn't let the car relearn correctly. On the procedure page ericem posted, you'll note that after resetting the ECU, you need to put the car in park, start it and let it run(idle) for 10 minutes or until it gets warm then you turn it off. This process allows the ECU to relearn the car. I think this is a pretty important step - which you probably missed due to not knowing about it.
The transmissions starting with 1994 seem to last longer than the 92-93 versions. Mine has 173k on it and it just slips a little during the 3-4 shift when cold. I also don't flog the car a lot either. I will say that the wheel bearings do go out fairly often. However, if they're replaced and get they get the correct lubrication (high-temp grease), they don't go out for extended (100k miles) periods of time. Parts can be expensive if you don't know where do look. Your best bet is getting stuff off of people who are parting out cars. And also, the rotors don't warp if you don't drive the car like you stole it. So, the history of the car is pretty important in how the car will probably behave if you buy it (ie, if it was beat, you'll have to fix it).
