Manarius
Everything posted by Manarius
There's too many tiny factors that go into that. Resistance of the fluid, the light dragging of the disc brake (you know disc brakes drag all the time), how well each CV joint turns, etc. In a perfect no friction world, I would agree with you - but just due to simple mechanics, there's going to be a wheel that doesn't spin even when it's off the ground. I highly doubt you have a dragging parking brake or anything that serious. If you're really that concerned, check how hot each hub unit is after driving for a little while. One that's noticeably hotter than the rest will give you a reason to investigate. Otherwise, I say it's just typical.
PA inspection is stupid. In Indiana, they don't even inspect cars. I would gladly help anyone pass PA inspection because it's a big waste of time. However, the ECU will be throwing a code for the ABS light and since the car's OBDII, it will be plugged into the system so it can be read. Which will nullify the whole "pulled out the ABS light" thing.
I want to put a turbo on my 99 imp ej22
Manarius replied to concretewake310's topic in Subaru Retrofitting
You might as well just start swapping engines. The NA compression makes turbo'ing that engine a pain the butt. -
You also said you feel like it's coming from the middle of the car - that even more points toward it looking like a U-Joint. Trannys don't usually vibrate like that just going straight forward, but if the U-Joint is shot, the driveshaft will wobble a good deal. I can't honestly think of anything else except maybe a broken/half broken motor mount that would cause a vibration unless it was unbalanced tires or something simple like that.
Carlisle, PA area monthly mini-meet
Manarius replied to nkx's topic in Meet n' Greet. Your USMB Welcome Center
Meet coming up tomorrow! -
car intermittently starts
Manarius replied to moonladymae's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would stick with the coolant temp sensor and possibly plugs as well. -
winter fun
Manarius replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I went up a unplowed moderately inclined hill with regular all season tires - about 6-7 inches on the ground (dragging bottom). I went up twice with no spinning - I had to jump on it to break it loose. http://img99.imageshack.us/my.php?image=dscn0164qb1.jpg
