Manarius
Everything posted by Manarius
Overrated? No. Overpriced: Yes. These blocks stock can take 400AWHP.
It's an easy swap. Josh did it without any major hitches. It doesn't require extra fabbing, just parts and electronics...and even then, most of the time it's just doing some wires for the Turbo ECU.
Then take the car and get it fixed properly. Many people have told you in this thread and the billion others you've made about the EXACT SAME THING to take the car back and get the transmission replaced. If the first shop did it wrong, get your money back and take it to the Subaru dealership so they can screw you out of your own money but at least it'll be fixed correctly! This should not be a reoccurring issue. The transmission needs replaced again. It was done wrong the first time. Numerous people have confirmed it and even the screwy shop you took it to said they screwed up!
EA82- disconnect rear axles for better MPG?
Manarius replied to Andy FitzGibbon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You're still towing around differential anyways. I can't imagine that removing the rear axles would save you more than 20-25 lb. -
I didn't say the block wasn't good for it, but you need to do something about the compression ratio in order to boost well.
Engine swap to the EJ22T. Don't bother TC'ing a NA block...it's not worth it.
