Manarius
Everything posted by Manarius
Because if someone who is new to this board sees this thread in a search, they're going to assume that all EJ style engines have "disasters" that are becoming common - which simply isn't the case. I think they should be...maybe "Problems to look for" but not common disasters, especially on the EJ22.
Funny. In all the posts at Legacycentral, I can't seem to find very many (if any) having anything to do with the Oil Squirters falling out. I'd call that very rare. Extremely rare even. There's a reason that any person who knows anything about Subaru's knows that the strongest block to ever come out of Japan is the EJ22T block. All of the EJ22 reasons listed here, aside from mine about the interference design, are MINOR problems when it comes to the overall integrity of the engine. I wouldn't call them "EJ Disaster" ideas. Also, what in the world does the 4EAT have anything to do with the EJ engine? We've already determined that the 4EAT is a great transmission.
1. Car doesn't have a carb so... 2. I think fuel pump as well. Is this 1/4 tank by gauge standards or when it does this, can you actually put 12 gallons in the tank? The gas gauge in these cars usually starts to lie by this point in time. 3. The fact that the ECU is throwing a code for the VSS means that you need to fix that. The VSS is probably causing the ECU to go into limp mode which is why the car would drive so slowly.
The transmission is almost 100% electronic. If I recall correctly, the Thottle Position Sensor is what the TCU (Transmission Control unit) uses to decide whether to lock up the torque converter (because there is no Overdrive in these cars). It may be that the TPS needs cleaned and then the TCU will decide to lock up the torque converter. Exactly what is "high" RPM's to you? At 60mph, the RPM should be around 23-2500 and at 70mph, the rpm should be at ~3000.
Same here. My car - as far as I know - has never been towed in its 154k mile experience. And, when it comes to reliability in my house, we all know we can go jump in my 1991 Legacy over the 1997 Camry and the 2003 Grand Prix. I'm extremely grateful to have learned how to drive in my '91. It's been a dependable beast (albeit, an electrically annoying one as of late). But, the nice thing about it is that if something breaks, I can fix it myself! I only have to take it to the mechanic for the things I physically don't have the tools for. You can't beat that. Add in the fact that I know the engine is good for at least 200-250k and you have a car that is well worth having. I seriously think that the drive train of my car will outlast the car itself (I'm in a losing battle with rust on the fenders). But, as long as it moves, I'm going to drive the car and I have no qualms on taking it anywhere.
I take issue with some of that. The early 4EAT's are not bad transmissions. They may get torquebind, but it's not fair to say that all of them get it and they get it between 70k and 120k miles. Mine and many others have gone more than 120k miles and have little or no torquebind. Torquebind is not a transmission killer as long as you don't make the car shudder all the time. The Phase II EJ22 may have a better torque band, but it is an interference engine which means that you need to change the timing belt more frequently and regularly or else you'll need a new engine. The old EJ22's are just as reliable if not more reliable than the newer ones because they are not of interference design. The Subaru 5MT is not a bad transmission as long as you don't beat it around. I saw one 5MT with 450k miles on it and it was attached to a turbo engine.
A few mpg...3-5 on the high side I think. I really think though that you should go through a few tanks, figure out your MPG, and then come back to us. Don't use the gas gauge, figure it out the correct way, came back with your stats, and we'll go from there. It may just be a winter gas thing or it could be something more. Before you go and throw money at it, we need to know hard facts.
