Manarius
Everything posted by Manarius
I feel like cleaning out an 'older' engine is a bad move. I wouldn't want to do anything that could potentially disrupt things that have already worn into the engine. I wouldn't want to disturb some of the dirt that has surrounded the rubber seals and makes them seal better. If you stick in some "cleaning" solution, you might end up finding a small leak of oil for yourself post cleaning.
OEM or Aftermarket? OEM, I use 1st Subaru Parts or Subaru Genuine Parts Aftermarket, I use RockAuto If the fuel filter is replaced and not the issue; I'd check Spark Plugs and wires. I don't think the coil is at issue here. If those don't fix it, my next vote is MAF. When my MAF failed, it bogged pretty bad.
I'd say that once I started taking things apart, I had everything back together after an hour of tinkering and looking around. It really isn't all that complicated; just don't lose any of the screws! It might be easier if you remove the driver's seat as well. On that car, it's probably only 4 big bolts.
If it's anything like my 95 SVX and 91 Legacy, it's a rather large bulb. I just started unscrewing the middle panel around the shifter until I could pry it up enough to pull out the bulb. Just go to Radioshack and buy the same bulb; 12 volts. Both were on the driver's side of that middle piece of plastic. There may be some screws in the bottom of the box between the seats.
192k? MAF's dead. Cleaning it may help. It may not. I'd be on the hunt for a cheap replacement/one to borrow to confirm diagnosis. I think the kind of acceleration hesitation you feel is due to the engine constantly misfiring at low RPM's, not because the transmission is holding it back. Does it buck under load? Rough idle? Shuts off randomly?
