Manarius
Everything posted by Manarius
spare key
Manarius replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Make copies....they don't come with them on the car - all keys are in your hands when you leave the dealership. At least, that's the way it is with the older cars... -
SVX Lovers
Manarius replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
SVX > Any Plymouth. SVX's are awesome. They're really interesting cars. -
First: Check all the electrical connections between the battery, alternator and starter. If they're dirty, clean them. If they're loose, tighten them. Second: Have the alternator load tested to see if it's putting out enough juice. If it isn't, that's the culprit. Third: If those things are all all right as well, I suspect that the starter is worn out (albeit that's pretty sudden).
My ASE certified mechanic with 30+ years experience actually recommended to put 20-50w in so that my car wouldn't leak so much. The weather around here doesn't really get that bad so I figure 20w at cold isn't going to kill the engine. I don't know what you mean by "low clearance" but my car has enough piston-valve clearance that it's not an interference engine - if that has any bearing.
I would think that letting the car run for those two extra minutes isn't going to do anything but annoy you. I personally don't start the car up from sub-freezing temps and just throw it in gear and drive away - I wait a little for the car to warm up so I don't go and break something. However, I'm pretty sure that solenoid wasn't meant to work like that.
