Manarius
Everything posted by Manarius
My car is a dog when it's cold. The fact is that the tranny fluid is cold and the car just isn't up to driving like a bat out of hell when the tranny isn't warmed up. I think this sort of idea can be applied to your car as well. However, the above mentioned sensors may be able to help you out slightly if your car is really slow.
Basically, aside from some body changes, dashboard changes, and another thing or two, the cars are EXACTLY the same. Sure, the A/C system manufacturers may be different, but it's all the same stuff. Now, the fuel rails on the 92-94 N/A cars are different from those of the 90-91 N/A cars, but they will interchange just fine. Oh, and in 1992, the swaybar went to C-Type endlinks, not drop style like the 1990-91.
Sure is. Wiring will be a real PITA (OBDI - ODBII swaps are annoying), but the engine and its components will fit just fine.
An N/A car can be boosted. It just takes money, tuning, and time. The biggest problem is tuning. The block can handle the PSI (Normal PSI; 8-10), but getting the timing to be right is usually a pain. Better to just get a stock turbo and either start swapping parts or do some tuning (all of which will violate your warranty).
Does yours look like this? http://discens.org/gallery2/main.php?g2_itemId=65 All it takes is a 10mm wrench and a regular screw driver. As far as I know, the plastic ones do NOT come apart. And the metal ones may need an allen wrench to come apart, but I would suggest against that. If it NEEDS cleaned (not that you just want to), use a cotton swap with rubbing alcohol. If there is nothing wrong with your car, would advise STRONGLY against taking the MAF apart.
