Manarius
Everything posted by Manarius
I don't think the front diff would like the instant change in speed of the wheels. I would then tend to think that the front diff would grenade if such a thing occurred.
The Max PSI on these is 35 psi and it seems that running max psi works just fine- I notice no increase in the middle of the tread pattern. I certainly don't use what it says on the door because that's far too low. From what I've understood, it's best to run the tires at or near the max on the tire for best fuel economy and tire wear. It makes sense to me that a harder tire would roll easier for better mileage.
New 07
Manarius replied to Alex C's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
All the new engines are interference so consider that in terms of reliability. But, otherwise, the engines are bulletproof as usual. -
That software will and has worked on the 1990-1994 Subaru Legacy's. Unfortunately, you're going to have to figure out what exactly is wrong with your connector so that you can get the voltage thing figured out. I think if you do that and read that the ECU sees, that will be the insight into what is wrong. Although, your ECU may just be crazy. Sometimes I think mine is.
