Manarius
Everything posted by Manarius
You could try one of those mesh/putty repairs. However, you would need to grind around that area pretty well so that the putty had some place to stick to. Something like this perhaps: http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?itemIdentifier=710675_0_0_&skuDescription=VersaChem+/+6.5oz.mufflerweld&brandName=VersaChem&displayName=6.5oz.mufflerweld&skuDisplayName=VersaChem&categoryNValue=10099999&navValue=100436&categoryDisplayName=6.5oz.mufflerweld&parentId=00-10&itemId=436-10&store=1883&productId=710675 They don't last that long though.
I had a 1991 Legacy at your age, a few more miles though (155k at that point). I think the best upgrade for that car is WRX rims. They fit just right and are larger than stock (16 vs 14). The rims you mentioned are 15's that come on the Turbo Legacy or mid-90's Outbacks. (Those are also 1991 Legacy SS's-turbos, they have about 160hp) Quite frankly, without a turbo, the only thing you can do to make the car sound good is go with a straight pipe or just some resonators with no muffler. I don't know the laws in your state but if you don't have emissions (I know Indiana does not have inspections) you could get away with making decent noise. Driving/Fog Lights are a good idea too. The stock headlamps are terrible (even when cleaned), so having some aux lights helps.
This sounds to me like a dying Mass Air Flow Sensor (MAF). MAF's cause stalling and all sorts of weird behavior. You can try cleaning yours with some MAF cleaner. I used 90%+ rubbing alcohol and a q-tip and it seemed to work okay. Unfortunately, if that doesn't work, you'll be forced to replace it. The sensors are not overly expensive as long as you pull them from junkyard cars.
Legacy 1994
Manarius replied to Conroe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It's too bad you're so far away from me. I have a spare lying around here just for testing purposes. -
Legacy 1994
When my MAF failed, the car wouldn't start or run. -
Legacy 1994
I'd check the Mass Air Flow Sensor. Try to replace the one you have with one you know that works and see if the car continues to act poorly. -
bad svx trans
Manarius replied to TN svx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My stock SVX trans has nearly 190k on it. It's the original trans as well.
