![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Manarius
Everything posted by Manarius
Yeah, well, you tell me when the average person is going to hit 140, because I'd like the see that. As far as I know, the highest posted speed limit here in North America is 80MPH. Only stupid ricers put big wings on their cars. The smart ones make their cars really plain so cops don't think they're going fast.
Well, he hot soldered wires together that weren't originally wired like that before. And because the system runs on resistance, it probably increased resistance on the system when he did that soldering. So, the ECU reads that as a higher resistance and therefore makes the blinkers blink like crazy. So, grounding out the system may perhaps alleviate the problem. I don't know for sure though because I'm not an electrician. The blinker system, while simple, is delicate and mucking with it can lead to some weird things, ie this person's problem.
All right. Here's my idea on this one. By soldering the wires together, you messed up the system and now that's why it blinks fast. Try grounding it out a little bit and see if that fixes it. And for the stop lamp, have you replaced any of the rear bulbs recently? The ECU reads the resistance across them and "determines" whether a bulb is out or not. This is a good system, but weird bulbs can give it a reading it interprets as a bulb being blown out.
In terms of shift speed? Fast. In terms of race speed? Slow. But, a dogbox shift is almost as fast as an Auto shift, and has the brain of a human behind it, not the retard logic of a TCU. Ask anyone who builds transmissions, MT's are faster than Auto's if driven correctly. Phil (BAC5.2) on the bbs had a dogbox in his old ABM SS...that thing flew.
Harsh Idle
Manarius replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Vacuum leaks usually cause weird idle...like it jumping up and down randomly. If he's just describing that the car when held to a stop while in drive vibrates a lot, I'm rather sure it's just the AWD system trying to move the car. -
Piston Slap
Manarius replied to bkcraun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Tick Tick Tick isn't piston slap, it's sticking HLA's. -
Harsh Idle
Well, I'm not sure about the intake then. The shaking is from the AWD system. Every Subaru with AWD that I've riden in has this sort of "shaking" issue when stopped and in drive. If you really don't like it, just drop the car in neutral at stops - I do. -
How much are you planning to increase the tube diameter to? If it's more than about 2.5 inches, don't even bother. N/A engines need backpressure to function correctly. No matter what you to do that engine short of major internal work, you're not going to get much more power out of it, it's that simple. And by much, I mean...maybe 10hp. And drivetrain loss in Auto AWD systems is A LOT.
Doubt you'd get 15hp from a N/A Exhaust set up and no, it probably wouldn't make any difference at all. If you want a fast car in a straight line, go get one with a Turbo and not AWD because those factors make for big time whp loss. But then, after doing that, you'll be like every other ricer in the world. Legacy owners are supposed to be cultured drivers, not lame-rump roast street racers like all the ricers.
Harsh Idle
PCV valve might be shot. That could account for the "gumming" in the intake. -
New SVX?
Manarius replied to ecky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Some random person just took a B4 Sedan, made it into a coupe, and added those windows. 100% photoshop.
