Everything posted by Manarius
Rear Wheel Drive
Manarius replied to TheMadMidget's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen I would suggest going and finding a different tranny and converting it to RWD. It's going to require some major changing of the internals, but it can be done.
Rear Wheel Drive
Manarius replied to TheMadMidget's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWeld the front differential would be my best guess. However, going to RWD w/ a AWD tranny is a real pain because it isn't electronics and especially not on a MT tranny. Sounds like you need to have one special built if you want RWD.
B9 Tribeca stinks!
Manarius replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know what you were smoking when you got in that thing, but the general consensus is that Subaru dropped the ball on the Tribeca. Underpowered, overpriced, poor leg room, and looks like rump roast.
Tires From Forester onto Legacy
Manarius replied to hutch85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rims will fit without problem. Best to replace all 4 tires at the same time, however.
Cruise Control
Manarius replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe entire cruise module? And assorted wiring and such? It's a major expedition to put in CC.
B9 Tribeca stinks!
Manarius replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, the B9 Tribeca is late in the SUV game - Forester has all Subaru will need in the SUV market. Subaru should have used the money they spent designing the Tribeca to redesign the God-awful front end on the Impreza's and do some upgrading to the Forester.
Won't start Metallic Sound while turning over
Is the turnover speed faster than normal? Maybe the TBelt popped off or snapped.
cloudy headlight lens remedy anyone?
Manarius replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm, wax will yellow over time? Interesting. I didn't know that.
Manarius replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnce again, clearcoat is the most permanent, but waxing helps....
Torque Converter - surging?
Manarius replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd try cleaning the TPS...that can sometimes cause tranny searching.
Manarius replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe oil method is temporary. For the best and most permanent results, sand and clear coat.
gas guage or fuel consumption?
Manarius replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bbs is the legacy forum dedicated to the 89-94 legacy's. We don't spoon feed everything to everyone, there's an expectation of a little brain behind the face. (http://bbs.legacycentral.org) It's one thing to help those who are not experienced. But it's another to spoon feed someone how to replace the O2 sensor. That's what Haynes and Chilton's manuals are for. We're here for troubleshooting, not for how-to's of things that are really pretty basic.
Need a little help with a coolant issue
Manarius replied to reeze's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think he means the Coolant Temperature Sensor. I have a picture here of what you should look for: http://www.discens.org/DSCN2628.JPG It's the brown plug that is the coolant temp sensor (if you look at the intake from the back, it's on the passenger side). It's about $27 from autozone. Hints for replacment (although, I don't think this is a coolant temp sensor case, but it never hurts to replace it): Deep socket so you don't have to work hard at getting it out. Park your car downhill (so the engine is the lowest point) to minimize coolant leakage.
Manarius replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGod, I wish people would think for themselves around here. Around the BBS, we don't tolerate stupidity. If you can't change the O2 sensor without asking for help of the specifics of how to do it, maybe you ought not to be poking around under the hood. I don't think I should have to spell out everything specifically. Fixing the car is trial and error on a lot of occasions, you don't need somebody to spoon feed you exactly what you have to do. Think a little bit here, my God, is that too much to ask? I'm 18 and I'm asking you older people to think, sheesh. Usually, it's the older guys telling us young people to not be ricers and do a little thinking, but around here it seems to be the complete opposite. Sure, I can understand a question of "Will the ECU just automatically handle the new O2 sensor or should I reset it?" or something to that effect, but "How do I change the O2 sensor?" My God, we're not talking rocket science here.
Timing belt cover!!!
Manarius replied to cyarmak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless you plan on going mudbogging any time soon, I wouldn't bother with replacing the cover.
Will 99 Outback exhaust system fit on 91 Legacy?
Manarius replied to dburdick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're probably right with 97 - that's the phase 1.5 EJ22 with the solid lifters and interference design (boo on interference)
Manarius replied to dburdick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOther way around. 96 and later are single port if I'm not mistaken.
Best place to buy?
Manarius replied to dacecil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo. If anything, 89-91 would be 1st gen, and 92-94 would be 1.5 gen. All that changed was a minor facelift, some very minor suspension bits, and airbags. Otherwise, all the 89-94 cars are exactly the same. Oh, and Legacy L's after 1991 didn't get rear sway bars, but that's about all I can think of. 1995-99 is gen 2 because that was the beginning of a very major facelift and OBDII.
Great to be back and find this forum, now just frustrated about all this body flex!!
Manarius replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy does everyone talk about it? Because it's true! You're not going to get it to drive like a Legacy now, no matter how much work you put into it. A bar in the front will stiffen the front, but not the back. The wagons always have more body flex, it's a product of design.
Best place to buy?
Manarius replied to dacecil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, the mounting points are there. They just used a different piece of moulding that didn't have the track. Canadian spec swap isn't too uncommon actually, it's just annoying ripping all the auto belt crap out.
Manarius replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI still think you're overexaggerating the problem. Your car is 13 years old with 13 year old technology, you can't expect it to be perfect, you have to expect it to act like a 13 year old car.
Manarius replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy car's rather tight for being 100% bone stock. Yes, I'm riding on 153k mile struts. Around corners, aside from the tall tires, the car rides like it's brand new with a little body roll. It barely flexes, at least, from what I can tell. My 91 also has a rear sway bar so that adds to a little bit of stiffening of the rear end. I personally think you're making a lot of out nothing. I think what you're making out to be flex is just normal operation of the car's chassis.
Manarius replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe clear coat will last longer than you will have the car. Let's not piddle about wiping a certain type of oil over the headlights - oil is oil when it comes to use on headlights and that's that.
Manarius replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI mean the sensor itself. The temperature of the coolant is vital to operation; the coolant temp sensor just makes your car act wacky(ie not start for a while) when it's warm. My point is that we're dragging out a thread about silly things like Coolant Temp and O2 sensor. These are basic sensors, not something we need 6 pages of spam about.
Stop Wheel Cover Loss
Manarius replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour opinion. I personally like hubcaps over black steel wheels. Why do you need zip ties? I've never lost a wheel cover and I've been driving for a while now - maybe you should pound them on harder?
