Manarius
Everything posted by Manarius
Well, you could probably start with a front strut tower bar (yes, one that goes from strut to strut), then probably you want to do something about the flex in the back of the car with another strut bar or some sort of brace. Then you could go to upgrading the front sway bar and putting in a rear sway bar.
89-94 is called 1st gen. They can be had without auto belts if you get a Canadian spec TLeg, but they're a rare animal indeed. Would probably be best to get a US Spec TLeg, find a Canadian spec Legacy with matching color belts and do a swap. Also, the 92-94 have Driver's Side Airbags if you're interested in more safety.
Coolant Temp does not screw with your gas mileage. Yours is working just fine. Get a new O2 sensor and stop dragging this thread on and on. Try some stuff out first before you go and just post more and more. Search some before you just keep going on asking questions. Coolant Temp and O2 are things even a total novice can do - you don't need to keep asking questions. Go to the parts store, ask for the part, buy it, put it on, it's that simple. We don't need to keep dragging on a thread about Coolant Temp and O2 sensors.
Non-interference for the win. OBDI for the ease of wiring. Plus they're in high supply, as opposed to the newer engines.
I don't know about you, but I wouldn't want to go around testing whether you can pull the shaft and just pull it around like that. I'm sure the manual says don't tow it unless all 4 wheels are off the ground for a reason.... Theoretically, that could work, but I certainly don't want to be the one who tests it and fries my rear diff. I'll be towing with all 4 off the ground - because I like my car the way it is. Absolutely not with 4 wheels on the ground and in neutral. You will fry a transmission like that, guaranteed. The clutch packs are sensitive pieces of equipment.
