Manarius
Everything posted by Manarius
Oh, duh, your car is a 97 2.5 GT. God only knows how to reset it and relearn the ECU on that car. I was assuming that you had a 90-94 legacy. You're going to have to ask someone with a manual to help you out on that one. I wouldn't reset the ECU until you learn how to relearn it. However, it would be smart of you to read the kick panel and look for the slot that says "ECU."
The fuse for the ECU is in the kickbox under the dash. As I recall, it's like position 15 or something. Pull that fuse for 45 minutes so it'll just reset the ECU, not the entire system. Then, after you've done that, put the fuse back in. Put the car in park and turn off all accessories. Turn on the car and just let it sit until it gets warm. Once it reaches operating temp, shut it off (~10 minutes should be enough). This stuff is all on Josh's website, it would be nice if you guys would look so I wouldn't have to keep repeating it.
I can't honestly believe you've gotten your rear wheels to chirp. I assume from the way you talk about your car that it's a body-kit clad EJ22E bearing car. There's no way I'd ever get my car to drop rubber, the AWD puts a stop to that. I've never tried doing it in FWD, never put that fuse in before, and don't plan on it.
1. There are no special tools needed. Just the wires, plugs, and a socket for undoing the plugs themselves. 2. In regard to the CC light - assuming that it's anything like the 90-94, just take the CC switch apart (the one that turns it on and off) and you'll find the bulb that's burnt out. Taking the switch out of the car shouldn't be too hard of a job - just a little prying and unplugging the switch. I don't know enough about the rest to answer them well. But those should be semi-useful.
I'm with grossgary on this one - resist the urge now and you'll love yourself later. Planning on going to college? Because you'll never get the money back that you drop into the car. I'm also with grossgary on the method of gaining power - however, I think it would be better to drop in an EJ22T than to turbo the N/A engine, but it could be done.
Changing the tranny fluid isn't going to make the solenoid engage any faster. If you're getting wheel spin, first I'd like to know how since I know my 130hp EJ22 is not capable of wheel spin even in FWD mode. Second, I think that you're over exaggerating the problem. I'd like to know how you can get your car to break rubber on dry pavement. Assuming there is something wrong, it would require removing the tranny to either replace it or some parts inside it. Why are you so concerned about 50-50 split? You're not going to need it on a daily basis anyways. And if you're trying to race people, I'd suggest against it - that's how young people like us get killed. Clarification: When the selector is in the 1st selector, the split will be 50-50 if the computer detects slipping. In other gears, the computer adjusts as necessary, using 50-50 in a worst case scenario.
Impreza mpg?
Manarius replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you want a high MPG car, the older 2WD Subarus would be best. But, you're going to pay a price for having AWD. -
Spoiled? I'd hardly call my 130hp EJ22 spoiled. I've driven my dad's 97 Camry (similar displacement, similar horsepower) and that thing was a dog(ie, it was slower than my car!). Then, I drove my brother's 87 Nova - that thing can't get out of its own way. I think 120-130hp is a minimum needed in order to provide you with enough power to execute manuevers necessary for safety.
There's still a split second of reaction time for the TCU. Completely normal. Consider that you have a car nearly 15 years old. Consider also that you have a tranny, while electronically controlled, is still bound by mechanics. You can't expect 50/50 split as soon as you put it in first, you have to cause the TCU to want to throw the split.
