Manarius
Everything posted by Manarius
Warp brake rotors due to overtightened lugs? I would think not. The rotors would need some sort of source of pressure and/or a bit of heat to warp. I don't see where that pressure could come from, so it would be then obvious that they would need heat to be warped. Well, heat doesn't come from over-tightening lug nuts.
a/c problem
Manarius replied to fixit72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Sounds to me like it needs recharged. The system needs to be charged correctly in order for it to run continuously. -
Most of the older radios (aside from those in the 1990-1994 Legacy's) don't have any sort of aux setup on the radio. Not even an AUX radio setting. However, the upper model radios in the 1990-1994 Legacy's had built in AUX 3.5mm jacks. The SVX didn't even get this radio (IMO, the SVX got a worse radio, but they didn't want to put a double din radio in the SVX and it not have a CD player).
For the 96's, a setup called "Morettes" were available for the car in Japan. Unfortunately, due to their beam pattern (Japanese drive on the left), they blind oncoming drivers in this country. My suggestion would me to wire up some relays for your headlights and go with some huge fog lamps if you need lighting that badly.
The caliper, rotor, and pads on that car are all extremely easy. All you need to do is take off the rim, remove the two bolts that hold the caliper on (these are like 15mm), and the rotor will come right off. For a first time, I'd say you'd need an hour at most. The biggest pita will probably be bleeding the caliper.
If I can do the plugs on the SVX without removing engine mounts or paying someone to do it, you can do the ones on your Legacy. Although, I disagree to pull plugs at 30k miles. That seems like a big waste of money on plugs which are meant to last 100k miles. Platinum plugs last that long if not longer.
I've mashed the brakes in my heavy SVX many times and NEVER gotten the ABS to come on unless there was snow on the ground. The one time I was afraid with ABS, it was because I made the mistake of going too fast when there was a very small amount of snow on the ground the ABS kicked in. I would have locked if I didn't have it and probably would have hit a tree or a parked car if I didn't have the ABS.
