Manarius
Everything posted by Manarius
What are typical component lifespans in miles?
Manarius replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Some of the things you mentioned are not mechanical. The ignition coil for example is purely electronic - so what exactly is going to cause it to break? The radiator - there aren't any moving parts, how's it going to break? If you keep your fluid changed, what's going to make it go bad? As for things like timing belts and water pumps - I've got a 150k mile water pump on my car that works just fine. The timing belt is almost 100k old and it still runs like brand new. Wheel bearings depend on use and so do axles. You can't just assign them a mileage that they're going to crap out. I've also got an alternator with 150k+ miles that puts out just as much electricity as it did when it was new. It's different for everybody, but a lot of the parts you mentioned have a lot longer a lifetime than what you wrote. -
Skid Plate
Manarius replied to moo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No 90 - 94's came stock with skid plates. In fact, I don't think they were even an option. I think I saw or read somewhere about modifying an Outback skid plate to fit on a Legacy. My question is, why do you need a skidplate? That's more weight you have to drive around, making your gas mileage worse than it already is. -
http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/118.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/119.jpg Those are the scans of the 90 owner's manual fuse pages. They're basically exactly the same as the 91.
Ben, you know I'm a faithful reader of the SVX forums - I see what breaks and what doesn't. I know I don't own one (dammit), but I've done a good bit of research to know what to look for when buying one or trying to diagnose issues. Of course there's no replacement for ownership, but by the same token, reading what owners have to say about the car and noting what's happening to them isn't a bad idea, right?
It can be either. My friend's like 97 drove like crap until the knock sensor was replaced. The ECU had retarded the timing so much that it drove like it was a slushy. I do have to admit though, the Torque Converter on the older 4EAT's is pretty aggressive. I don't know if that has anything to do with the "butt-o-meter" rating, but I personally think that my 91 L AT AWD is better off the line than my friend's 97 even with the knock sensor replaced - and her car has mor HP than mine (not too much though). It could be a final drive ratio as well. The 91 is 4.11, the 00 may be 3.9 or 3.7 which would make for a very tall 1st gear, with slow start.
