Manarius
Everything posted by Manarius
Could be no fuel either. You should check to make sure that you actually have fuel pressure. This can be done by removing the "in line" that goes to the fuel filter, sticking it in a bucket, and trying to start the car. If the bucket has gas in it, you know you have fuel. Things I always start with when it comes to a car that won't start is gas and spark. Pull a plug to see if it sparks and check to make sure you have fuel pressure. If the timing belt is broken, as Gary mentioned, that will make your startup impossible, so check that first as that's the easiest
Just like every other 1990's Subaru car, the SVX has the parking light switch. On this car, it just happens to be next to the heated mirrors switch. I think it's awful hard to hit by chance as I rarely ever use my heated mirrors. As for the foglights, if they are staying on when the headlights are off, then you've got some serious wiring issues you need to address. SOP for the foglights is that they don't work unless the headlight lowbeams are turned on. And in that case, the lowbeams are wired such that they will not stay on if the key is not in the "ON" position. By the way, the SVX is a GREAT car in the snow and ice. Put a good set of snow tires on it and it just won't stop. My SVX, even with crappy summer tires, plowed through 4 or 5 inches of snow without a problem. Remember, the SVX has a rear LSD, so it has another wheel in the back that your BRAT probably doesn't have (unless you put a LSD on it).
A/C question
Manarius replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My SVX's refrigerant seems to leak out every winter and I have to recharge the system every spring/summer... -
It seems to me that if you aren't going to at least run the cones into the fender, there's no point in wasting your time. Having air intake from under the hood is a waste because the hot air provides worse HP than the stock intake resonator. Also, it seems to me that the less restriction in the intake the better. But, the least restriction possible would be having only one pipe, not two. I mean, there's a reason that almost every intake system provides only 1 intake filter.
Well, for one, the engine that was in the 1997-1999 Legacy was also in the Impreza 2.5RS and Forester so... If you're *really that worried about HG issues, either get one that's been fixed or get a Legacy/Forester/Impreza after 2002. At that point in time, they had fixed the gasket issue. Or get a Legacy before 1997 or get one that has the 2.2.
I bet the CEL is being thrown for the VSS. The VSS is the speed sensor that tells the car how fast it's going. Hopefully, it's just that the sensor broke. However, some transmissions break the little plastic gear inside the tranny and that in turn throws off the VSS and makes your car throw a CEL. Replacing that gear is a very time involved job. The sensor isn't as bad. The first thing I'd do is make sure the speedo cable is plugged into the cluster okay. After that though...
