Manarius
Everything posted by Manarius
I think the answer is no on both accounts. I've never seen that generation with hoodscoop or projector lenses.
Just to reiterate, don't get the wrong idea about the SVX. It is a great car. Every SVX owner will tell you that. However, all of them will also say that it's not the best choice for a first car because of the things grossgary and nipper mentioned. You might just wanna pick that SVX up for yourself. I'd go test drive it...you'll fall in love.
I agree with Nipper. As much as I love my SVX, I don't know if I'd trust it to a 16 year old. If it gets wrecked, it's totaled for sure because of how expensive the parts are. I'd get an early Legacy (91-94) or Impreza. Just as reliable, just not as rare or costly to repair. Also, that model is LS-L not LS-i. LSi started with the 1994 MY.
Maybe someone here will have an idea. I've been having trouble with my SVX ever since I replaced the plugs back in the middle of May. The problem is this: The car stumbles fairly badly when cold. It also can't find idle and stumbles enough to shake the engine. It will also stumble randomly when warm. Seems strong if I am really hard on the gas. Here's what's been done: Tested to see if the stumble follows a coil - no response from the car Replaced fuel filter Replaced front knock sensor (ECU threw a code - sensor was broken) Greased all coil boots with dielectric grease Replaced MAF with known good MAF Cleaned throttle body with TB cleaner Cleaned IACV with TB cleaner (emptied about 1/4 of the can into the IACV, made lots of smoke) Ran Seafoam through gas Sealed minor exhaust leak Replaced two of the plugs because I *thought* they might look bad. Here's a video of a bit of my drive to work in the morning: You can see that the car definitely sounds and acts weird when it's cold. It's not really safe and it's really really annoying. If anyone here has any ideas, please post them. I'm willing to do almost anything to get rid of this.
You could use a WRX auto or 5MT. They could handle the torque and power...but you'd need the matching rear differential.
Rear brake Conv., while there should I?....
Manarius replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since you already have it apart, it only makes sense to put in new grease and seals. Otherwise, I would agree with it being a waste of time. -
Back in my 1991 Legacy, there was a connector under the back passenger seat that would tend to melt and cause the fuel pump to not receive voltage. I don't know if the early Impreza suffers some this same problem, but it wouldn't hurt to check. I would also check the connection directly at the pump. The pump should be accessible from the trunk.
I disagree. I purchased a kit with a low side gauge and filled my system to the proper amount of coolant for a price way lower than what a professional would have charged. You just have to follow the instructions on the container - it's not that hard. The gauge tells you how much pressure you have in the system on the low side. Just add enough to get to the right PSI and you're good.
