Dr Subenstien
Everything posted by Dr Subenstien
  1. i saw a early 90s honda prelude today with 4 wheel steering and it made me wonder if anyone here has attempted this modification? I see there is not much you all have not tried
  2. Spray carb and choke cleaner around the base of the carb and listen if the moters sound changes if it does change then you have a leak on the carbs seal at the intake be carefull not to start a fire with the carb cleaner
  3. take off your heat riser tube that goes from the air cleaner to a shroud on the passenger side exhaust if it smooths out there is a hole there it happened to me once the intake was sucking in a whole lot of exhaust gasses and making it run real bad good luck
  4. I have gotten one out of a loyal it took a while to get started I used stiff piano wire and used it like a saw like the others talked about but it was a pain in the a** i found the stiff wire works well but it is smooth so not much friction for the cutting
  5. there is a shop off of baptist church rd between lindbergh and tesson ferryI think it is a MARKII auto center I have heard good things about also at Manchester and 141 there is a place called Roy's sevice center that I have used in the past with no complaints. good luck
  6. A friend of mine and i talked about putting a samuri under a brat body we even had a name for it suzukarusamabrat
  7. oops did not see ebay links on todds good luck but they were there
  8. I had the same problem with one I had thst sat it took a real good deep cleaning of the carb and a few hard miles on the highway to clear it out also make sure the engine is really warmed up before the test
  9. I have an 84 Brat that is about to go under the knife after i find the rest of the parts I need daily driver 03 f250 fun driver 89 bronco full size
  10. sure looks a whole lot differant and better thank you for the pic glad to see it is still around Tim
  11. so it is still around thats good to hear sounds like it is traveling around a lot but is it under its own power or a parts car wish i had it now also glad to see more mid westerners tim
  12. When I was on this board before there did not seem to be many mid westerners but I see membership has grown there has got to be others here now
  13. no pics yet it is not much to look at now being wrecked and all but hopefully by spring will be back on the road
  14. Hi I was a member ages ago and now I am back and getting ready to repair my brat glad to see this board still exists looking forward to talking to you all
