rol1
About rol1
- Birthday 11/13/1954
Location
Las Vegas
rol1's Achievements
Advanced Member (3/11)
10
Stupid and expensive mistake- 91 loyale starter
rol1 replied to Todd in Seattle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Go to junk yard and get the copper contacts from old starters. You can see which ones are worn. Easy fix for most starters, don't buy new starters without checking the contactors first. -
92 loyale has them under the hood as he said. one for test, one for stored codes, and both to clear stored codes.
Sounds like what my 92 Loyale did when I bought it from the auction. It would pop for a second then die with a shot of gas. It was the fuel pump. If it caught before, tried to fire, then the problem must be intermitent if its the dist or cas.
What about color coordinated silicone boots and polly bushings? Yellow, red?
Those coiled jelly-cells may not test as a regular battery. Go get it tested a a place that is authorized to deal Optimas.
What can I do with the ea82 to get some more pep?
So this has a 2wd so could I use this distributer with my 92 Loyale? As it suggest for N/A power tune-up? What HP does this mpfi xt4 ea82 have?
1987 5spd shifter bushing sizes and prices
rol1 replied to amartin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A penny to make and $10.00 to sell???? Why, thank you very much. Was it good for you too? I'm a little sore though without the Vasoline. -
How come these pistons not look the same?
rol1 replied to subynut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks like this is one of those times a factory piston from subaru, OR, get to pick-a-part and find a factory piston for $5. -
There was a article in the repair manual off the homepage link above. The author welded his own tops and showed how he did the whole thing. The link has been down but maybe somebody had saved the page and could post it here? I've been looking for it.
Vicious LSD 3.9 Rear end/EA82 installation
rol1 replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since the SVX was NA, was it a 3.9 LSD? And thanks for the replies. -
OOOhhhkAAA, so how do I know which type is which?
