tunered
Everything posted by tunered
Have you ever seen them grooves in a crank where the seals have been riding? Well things dont get bigger as they wear, the seals were kept soft and to a small degree swollen against the crank by the additives in dino oil. Synthetics either didnt have any or enough of this additive to keep the seals swollen. Therefore after so many miles they started to leak. Theory and real life are not related. This forum could not hold the complaints of leaking oil. If you own a Nissan look in your owners manual before changing to synthetic, i have been told that some models they recommend not to use synthetics. [ Have not read this myself]. ed
Heres whats happening, at idle no 1 is dead, slowly increase rpms, at about 1700rpms engine smooths out jumps to about 2100 rpms , unhook no.1 injector and engine will not smooth out at any safe rpm. If you unplug iac, idle go's up to 1000rpms, wont stall but idles fast, pluged in idle is normal. HELP. Thanks. ed
Been awhile, been two years since i had any trouble, now i have no.1 dead. Pulling injector plug off or on has no effect. Every once in a while this car would have a miss at startup when hot, shut off, restart, would be fine. Im thinking injector, any ideas, have one for sale? 91 leg. 2.2 auto Thanks. ed
Let me say first that i am no expert, come from the old school. A blown head gasket should repeat the same symptoms time after time, not come and go. i have seen low coolant level do the exact same thing, including bubbles, trying to release the trapped air in the system. a simple pressure check should reveal any leak the system has. ed
