P1104 Engine Torque Control Signal Circuit Malfunction ????
what year and model?
possible torque bind
johnceggleston replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXput the fuse in and see if it helps. you can drive it that way a long time but you run the risk of the duty c failing. (the fuse will not do any good if the duty c is already bad but then you should have a flashing AT TEMP light at start up.) short term, until you can fix it is fine. if the fuse helps, a fluid change, (drain and fill 3 times, not a flush) may help or fix the problem.
My second soob! Now w/pics!!!
given what the engine needs, i would pull it and the head and then make the decision. let the condition of the inside make your decision for you. it's probably fine. it was getting more gas than it should but it was also still getting oil. dropping in an engine is easy but you already know you should: replace ALL the timing stuff and ALL the seals. so your $160 engine is going to be a little more than that. but the same is true of the one you have. i'd probably replace the engine and sell the old for parts. the driver side head and intake can bolt on to a 90- 94 engine and make it an ej25 swap motor. someone may want that. or save the parts if you plan on doing this again.
4EAT vs. 5 spd
not the same lift, but you could add the outback 96 - 98 struts to get it . the fog lights are different as well as the front bumper, but most people wouldn't notice unless they compared them side by side. the piant job makes it look like an outback. 96 outback 5 speed has the 2.2L engine and all of the ''real'' outback stuff.
Exhaust Leak on 97 Impreza OBS
johnceggleston replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno, the flex joint is in the exhaust between the cats and the mid pipe. it is spring loaded. the EGR heads and the non - erg heads are the ''same'' except the egr driver side head has a threaded hole on the back side for the ''exhaust to egr'' connection. (it connects the exhaust port of the head to the egr doodad on the intake.) i looked around online for a picture, but no luck. if the engine is original and stock this is not your problem. but there was an exhaust leak problem in this regard during a recent swap. on the other hand, if some one has done a swap, all bets are off.
HOLD THE PRESSES. i swapped in another ECU from a 98 and both of my codes, p1104 and p0441, went away. apparently it is not a problem with the car, or the ''torque control'' or the ''evap flow'' but a difference in the ECUs and the ''pin out''. so i suggest finding a new ecu from a 98. mine had a ''Z1'' om the cover. i'm not sure it will help with the p0507, but the other 2 went away. after the ECU swap, and the first drive cycle, i had a p0440 pending. but after the second drive cycle all was clear. i will report back if it changes.
90 Legacy L overheating
johnceggleston replied to billtom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe ej22 engine, which you have is surprisingly good, even with trouble. you can get a replacement for 300$ , 150$ if it is a u-pull-it. swap the engine and drive on . but chances are good that it will run forever if you replace the gaskets. not hard to do but still a job. for me it would come down to the cost of the replacement engine vs. the parts. but gaskets are cheap and do not compete with the the replacement cost of an engine. regardless of what you choose, re-place or re-gasket, you will want to replace the timing belt and all of the idlers. good luck.
replace battery and car won't start?
johnceggleston replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXput the key in the ignition and turn the key to start and let go. DO NOT TOUCH IT AGAIN. open the hood, disconnect the negative battery cable and wait 2 minutes. reconnect the negative battery cable. get in the car. turn the key to off and then try to start the car again. report back here.
Replace head gasket? How?
alvaro, this seems to be your longest recent thread, use it for all of your questions regarding this project. there is no need to start a new thread for each question. those of us who are here every day are going to read what ever you post with little regard for the title. posting a new thread for each question is a waste of time and computer space. good luck and keep at it.
fuel pressure releif
don't mess with all of that. wrap a rag around the fuel line leaving the filter and pull it off. the rag will soak up the fuel, if any, and then carry the rag out side to evaporate. there isn't that much pressure. or that much fuel. just make sure you have a rag handy and that your drop light , if you have one isn't near by. by the way, if you haven't disconnected the battery yet you need to. you don't want sparks floating around. usually by the time i get around to working on a car, it has been sitting so long there isn't any pressure at all.
4EAT vs. 5 spd
don't take the first offer. find a comparable car for sale and show it to them. the offer may go up.
johnceggleston replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe egr pipe runs from the intake on the driver side straight down to the rear of the head. if the pipe, about 3/8'' - 1/2'' diameter shaped like a staple, if the pipe isn't there you should be able to get your hand down in there. if it is leaking i would think you could here it as a loud exhaust sound.
86 & 98 Legacy compatibility question
johnceggleston replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust so you know..... there are a few, very few minor differences, like headlights, 2 piece vs. one piece, but most everything will swap. all the mechanical.
glad you got it. looked like a good one. my money is on jumped timing belt.
External Coolant Leak on 97 OBW Already Did HG's
so this thing leaks when sitting over night? or only after it has been driven. park it in the drive way and let it idle for a while. at least a little while after it gets to operating temp. if it leaks when running you should see it drip. i would look around the area of the rad cap and over flow bottle and then the water pump. my guess is that the rad cap was removed to conduct the system pressure test, so it didn't get tested. cardboard is good too.
RE:Transmission Removal
no difference. same trans. same final drive ratio. if you want you can study up here: http://opposedforces.com/parts
ABS and Cruise Contol?
jazz, did you see this one? better hurry. it could need a valve / head job but until you look, who knows? maybe fairtax could diagnose it for you. he lives up there. maybe the timing jumped??? if it does need an engine offer $400. http://charlottesville.craigslist.org/cto/2208370442.html 1995 Subaru Legacy LS Wagon - $800 (Lake Monticello) Date: 2011-02-10, 11:25PM EST Reply to: sale-r3ypa-2208370442@craigslist.org [Errors when replying to ads?] 1995 Subaru Legacy LS Wagon, 178,000 miles, Automatic, AWD, ABS, PS, PW, PL, AC, CC, AM/FM/CD stereo, sun roof, spoiler, fog lights, front passenger airbag. Well maintained incl. regular oil & filter changes. New brakes, new starter. Interior in great condition. Runs but engine needs some work (possible valve job). 2nd owner. Left front fender has a small dent from a deer running into it. If interested, email me and we can arrange a time to see. Located at Lake Monticello. Location: Lake Monticello it's NOT ok to contact this poster with services or other commercial interests
2001 Subaru Legacy L modifications
johnceggleston replied to gmgsci's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe one exception to all of the above is, if you want it to be ''quicker'' you might be able to affect this a little bit. if you use smaller tires. the 97 GT has the same trans as the outback, but smaller tires. the result is a ''sportier'' set up. so i would look into smaller tires and maybe taller struts, outback struts. (assuming the 02s are similar to the 96 - 99.) but any energy and money spent on ''custom intake'' or the similar, is just wasted.
Tie Rod end play
johnceggleston replied to Luvn737s's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmost of the tie rod ends i have dealt with, all subaru, are pretty tight. it takes a fair amount of force with my fingers to move, swivel, the threaded piece. one i removed last fall moved pretty easily, much less force required. no unusual movement , just less force required. when does the tie rod end change from ok to not ok.? i replaced it, but i was just trying to learn at what point does it becomes too loose?? thanks
i don't think the abs wiring goes any where near the cats. so it may have happened at the same time but probably not because of the cat removal. the ABS problem could be build up on the sensor, metal filings or rust. mine has set a light in heavy snow. cats are more than $100. rather than buying a generic inexpensive cat, i would buy a cat off of some one parting out a car. often, a used subaru original part is a better buy than a new after market part. (there are a couple in NC, raleigh / greensboro, maybe) the used parts yards can't sell cats and the metal scrap companies around here don't pay much for them, $15 - $20. this guy has the whole car for sale. http://raleigh.craigslist.org/pts/2193314680.html FYI, the timing belt is due at 180k and if he had done it already he would have said so. that will run you 600 - 800 at a shop, maybe more. if the belt or an idler fails you will be looking at a head job instead of a timing belt job. it would likely cost double. if the car is clean and you like it then i would try and talk him down a little and go for it. let us know what happens.
Key fob replacement
talk to ''lmdew'' i've gotten a couple from him.
EJ22 Timing Belt Question
the tooth count for one side is something and 1/2. in other words, the other two marks are on a tooth, not a valley but one cam is in a valley. the question you need to ask is , if you adjusted it one tooth over would it be closer or farther away. if closer, then maybe try it. if farther away, then leave it be. it's probably fine. the 2.2L is prety forgiving and yours will not have any damage if wrong or if it breaks. i think you are good, lots of folks have ''seen'' this and are happy. give it a test drive. how does it run.?
Transmission parts interchangability??'s
johnceggleston replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, the parts will interchange. the assemblies are the same except for the front section closest to the engine with the differential in it. the ring and pinion are different. the rear extension housing with the AWD transfer clutch in it may be sellable. you will have 2 of them to sell, assuming you don't have torque bind.
What is this part?
yes, the over flow only.
Need <$5K car for my daughter, should I avoid all 2.5 models?
johnceggleston replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is conditional: 96 - 99 are sure fire head gasket issues. plan on it, if you miss it, more power to you. 00 - 02/03 are maybe HG issues, much less likely but not for sure. 03 and beyond the likelihood seems to be the same as any other aluminum block/ head combination. just so you approach the problem from the correct perspective. first time sellers may not be aware of this but repeat sellers probably already know. good luck. ps: i have an ej22 / ej25 swap for sale, outback or GT, your choice.
