johnceggleston
    8
  1. where are you getting your trouble code definitions? p1104 is for torque control, a circuit problem i think. it has nothing to do with the tps. adjusting the screw on the throttle body can screw up how the cart runs. put it back the way it was and leave it alone. if it was right in the other car it will be right in this car. here's a link to a 97 FSM it has the codes and procedures for sorting them out. it may take some time to hunt and find the section you want. http://www.main.experiencetherave.com/subaru_manual_scans/1997_Legacy_FSM/ p0441 is an evap purge fault problem. the link i gave you had possible causes and solutions lower on the page. (see below) not subaru specific, i don't think but good enough to start sorting it out. the part that made sense to me was ''faulty purge solenoid'' or ''Corrosion or resistance in purge connector'' the previous owner on my car backed into the ocean unloading at a boat ramp. salt water equals corrosion. i guess it could also be a canister full of salt water? how did your ECU get wet, corroded? i have the time for a long story. Causes A code P0441 could mean one or more of the following has happened: Bad vacuum switch Broken or damaged EVAP line or canister Open in PCM purge command circuit Open or short in Voltage feed circuit to Purge Solenoid Faulty purge solenoid Restriction in EVAP solenoid, line or canister Corrosion or resistance in purge connector Bad PCM Possible Solutions With a P0441 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try: Common Chrysler fix - Replace Leak Detection Pump / LDP Repair damaged EVAP lines or canister Repair open or short in voltage feed circuit to Purge Solenoid Repair open in PCM purge command circuit Replace purge Solenoid Replace vacuum switch Repair restriction in Evap line or canister or soleniod Repair resistance in purge connector Replace PCM
  2. 99 speedos have a known problem. there is a thread i stared with a fix. i found it on another board. it is apparently a circuit ground problem on the circuit board. there are pics in the thread, or at least links to pics, for the fix. in a thread just last week there was a solution for a non-working speedo of another year. in that case it was the screws mounting the speedo to the cluster circuit board. loose screws meant no speedo. but for 99 it is on the speedo circuit board and a wire has to be added. and 99 is slightly different than earlier years and you can't just swap it out with a 98. (something about 3 wires vs. 2 wires but i have not confirmed that.) advanced search ''speedofix'' or ''99speedofix'' posted by me. if you use this fix and it works, please post back here or on the speedofix thread and let us know.
  3. if the exhaust has a leak under heavy acceleration i would check the donut gasket just to the rear of the trans where the cat meets the mid-pipe. it is usually a spring loaded joint and heavy acceleration can be more pressure than the seal can handle. but , that is not right rear, it is very much center center of the car.
  4. the 96 outback had taller struts, larger tires and bigger front calipers. the 95s were a legacy with outback paint / trim. but the question is did the 95 have the lego calipers or the 96 outback calipers. probably the lego but who knows? but since you have both wheels, try one on the front. if it works, the rears will be good.
  5. runs fine with or without the ground. i haven't addressed either one yet. my current thinking is that the evap is the solenoid or whatever it is next to the canister in the back and the torque control is either a bad wire connection, corrosion maybe, or a difference in the wire harness/ ECU. did you try and run the engine on the 97 ECU?
  6. easier to buy a 24'' long piece of flat steel and 2 longer bolts that thread into the crank. drill 2 holes on the steel bolt it to the back of the crank and presto you can torque away. works for removing and installing and you don't have to move the engine around as much. but the impact wrench is way easy. just hard to measure the torque.
  7. it sounds like wide open throttle changes things. what does the ECU do differently at WOT?
  8. i'd be tempted to put it on blocks or jack stands and reduce the tire pressure to half of normal. bagging them in plastic will help as well. tires sitting for 2 years may become out of round.
  9. installing the FWD fuse under the hood grounds out the wire and therefore it grounds out a pin on the tcu. so my guess would be a wear spot on a wire in the harness somewhere that is grounding out. good luck.
  10. the 4eat phase 2 trans was introduced in 99. the biggest change at that time was they added more sensors to the trans. they look just like the speed sensor on the rear transfer housing. (also like a cam or crank sensor) the addition of these sensors means there are more wires in the harness and more pins in the connector. the trans code id numbers changed as well. phase 1 auto AWD trans start with TZ102Z... phase 2 in 99 started with TZ1A2Z... i think and later TZ1A4Z... i think. 99 mat have been a transition year and it is POSSIBLE that it would not work in a later car but i doubt it. i don't really think any of these are a one year trans. you can not rely on the interchange software at the salvage yards to be accurate in this regard. if they say it will fit , it will. but just because they say it will NOT fit does not mean it will not. case in point, if you search for a 96 outback auto trans, they will not return any 97 or 98s in the results. and they will work just fine. or when looking for a 97LSi auto trans it will not offer a 97GT as a solution. and the only difference is the speedo gears due to different size tires, same goes for outback. if the trans code number changes, the software thinks the trans changed. and it may have, but it may still work. so the rule of thumb is this, if the trans is from your year group, 95 - 98/99 (depending on the model) or 00 - 04 (i don't really know the particulars) and if the final drive ratio matches, and if the wiring connector matches, it will work.
  11. some one posted years ago, (and i don't know if it is true) not to spray the nuts on those 2 studs. with luck the studs will thread out of the housing making it easier to drop the diff. it sounds good, but i don't know, never done it.
  12. at http://opposedforces.com/parts where you found the trans number. but instead of transmission, look under train, as in drive train.
  13. it should be, yes. if the wire connector matches the one in the car it should work. check the ring and pinion ratio. it would be listed in ''train'' section. if that matches the one in your car then it ''should'' work. where did you get the trans? how much?? any warranty ?
  14. first, what's the code on the other trans? that will help. second, the trans number you listed is definitely a phase 2 trans. third, look at link below for more trans number info. http://opposedforces.com/parts
  15. what year engine did you install? 93? newer?? did you swap the intake or use the one on the ''new'' engine? i used a 95 ej22 in a swap for an outback and had an exhaust leak, the EGR tube between the intake and the driver side head was missing. ran fine, no codes, but big leak. feel for an open hole or escaping exhaust on the rear of the driver side head. be careful of the heat. 93s don't have an EGR , i don't think, but 95 - 99s w/ auto trans do.
  16. the wear pattern on your pads indicates that your calipers are not ''sliding'' as they should. IIRC: the rears are set up slightly differently from the fronts. or maybe the outbacks are different from the legos, whatever. on some the bolts are long, one per caliper and the other slide is an actually pin. they both need to be cleaned an lubed. on some the bolt is inside the actual ''slide pin'' which is really more of a tube. on these re-geasing the bolt does not really help, there is no ''sliding'' happening on the inside of the ''tube''. so the slide pins / tubes need to be removed and re-greased on the outside of each. and on some models, i think, the bolts are short and actually bolt to the slide pins which are threaded into the calipers. but i'm not sure. those may be on later models?
  17. the 4.44s were in the 2.5L engines in the legacys at least, not sure about the 2.5L engines in the imprezas (if there were any 96 - 99). the 95 impreza auto has a 4.11 diff.
  18. mine would come on occasionally last winter when we had deep snow and would reset it self when the snow melted off the wheels, hubs, whatever. it actually reset itself before i could even check it out, but it happened several times during deep snow driving so i just figured that's what it was.
  19. i thought the rear sections were all the same, it was the fronts that were different lengths for manual and auto trans.
