9
you have to jack up the trans so you can angle the engine down a little in the front. this will allow you to bolt it together and then lower it down. i put a block of wood under the front diff area just behind the cross member and lift. it helps if the dog bone is disconnected on top of the trans. how did you get it out without jacking up the trans???
i bought mine from a guy who bought it for his engine repair. he paid retail, i paid half. they are not terribly expensive, especially if you resell it and get half of your money back. the bigger issue for me was a roof to work under. i don't have a garage, just a shed i can nose into. pulling the engine in the drive way / parking lot versus pulling the heads in the car i might opt for in the car.
if your timing belt was making that noise i think your car would quit running fairly soon and there is NO WAY for the timing belt to contribute to the RPM problem. we can only offer opinions and advice based on the info you give us. we can't see or touch the car. so when you say the rpms went up and the car didn't accelerate that means bad clutch. when you say squeeling noise we say probably the clutch, but it could be the AC or alternator belt. but neither of those would cause the RPMs to fluctuate. it doesn't sound like you are very happy with the conclusion that the clutch needs to be replaced, i don't blame you. but if you replace it you can drive another 150k? miles without messing with it again. i'm not a clutch guy, but i would guess a shop would charge $500 - $600 for a clutch job. it that a realistic price range?
it is hard to say what was causing your ''popping'' when turning. it could have been the ''transfer clutch'' or it could have been the mis-matched tire. or maybe an axle, that would have been my guess, but probably not. but here's the problem now. you paid for a repair, more than the going rate, but you did get new tires so that eliminates some of the over charge, you paid and they failed to repair it. now they are tinkering with your car and will probably fix it but you paid for something you did not need. i would be very upset. there is no reason for them to have not fixed it the first time correctly. i would ask for your money back. they failed to fulfill their half of the contract. and even if they fix it now, as you said, you didn't need what they did. i'd go get the car before they say you need a trans. the line about the additive is just an excuse to justafy working on it more so they can find the real problem. and they say the flush has helped and is needed, but you have no way of knowing unless you drive it. some one here had their transfer clutch rebuilt for 900$ at the dealer 4 or 5 years ago. tires are $400 - $500 max.(mine were ~$375) they overcharged you and didn't fix it. good luck.
google trans rebuild kits. some one, nipper i think, posted a link last month or late fall. there are companyie that sell parts for rebuilding an auto trans. i'd look there and maybe search nippers threads. it's a place to start. call them. http://www.ultimatesubaru.org/forum/showthread.php?t=118510 EDIT: ooops, i didn't read all of the earlier posts before hand.
i don't know about current OBD systems on any cars, subaru or other, my newest car is a 98. and obd2 is a good thing even if it was government mandated. but for subarus in the late 90s, lots of thing can go wrong, be failing, old and tired, cause problems, without throwing a code. so if a sensor outright fails or is disconnected you get a CEL but if it's just not working properly you often get nothing. and then figuring it out isn't really helped by the OBD system. now, back to your regular program.
3. Engine does not return to idle. 1) Idle air control solenoid valve 2) Engine coolant temperature sensor 3) Accelerator cable (*6) 4) Throttle position sensor In this case, repair the following: Poor contact in throttle position sensor connector Poor contact in ECM connector Poor contact in coupling connector (B21) 5) Mass air flow sensor
your math appears to be correct, but have always understood the second number to be the distance from the wheel to the outer diameter of the tread. not the width of the tread. but i may be misunderstanding the terminology. the diameter of the 205/75/14 is ~26.10''. stock outback, late 90s, is ~26.30'' stock legacy, 185/70/14, is ~24.20'' but all of these number are theory, actual tire size may vary.
true, but standing out front with a sign may be the stick that gets their attention. some one posted recently that they got no where until they started picketing the on the sidewalk. small businesses can't afford to have customers, old or new, turn around and walk away. ''protesting'' on the sidewalk will not scare off all customers, but it willl make a lot of them think twice. repair shops tend to have a bad reputation any way, regardless of how honest they are. kind of like home improvement contractors. at least until the customer has had a good experience. maybe park you car out front with signs in the window if you don't have the time to do it yourself. but nothing is better than a complaining customer out front. and one more thing, if and/or when they talk to you, get everything in writing and signed. that way they can't back out.
i would agree with what others have said, but i doubt that the shop owner will. i would be surprised if he / they acknowledge any fault at all. so you will have to ''convince" them. i think i would start with ''give me my money back and pay to have my engine repaired by the dealer''. and then introduce them to the BBB and a lawyer. and if you have to park out front of the shop with a sign saying they do bad work and cheat the customer. i would settle for getting your money back. you can use that to make a good running car to keep or sell.
P0325 -Knock Sensor Circuit Malfunction the hesitation could be the knock sensor. mine was old and tired and caused hesitaion under slight load, driving uphill. if i punched it it would eventually catch and go. mine did this for a while before it threw a code. P0325 is actually a circuit problem that could be a connector or corrosion under the sensor, maybe. but depending on the miles, it may be due anyway. P0500 - Vehicle Speed Sensor Malfunction any speedo issues? does the AWD work properly? if it is an auto trans, put the FWD fuse in and take a test drive. see if you can feel a difference. i usually can. P1101 - Neutral Position Switch Circuit High Input (A/T) P1101 - Neutral Position Switch Circuit Malfunction (M/T) i have no idea about the last one? but it too sounds like a circuit issue?
when i said scantool, i was thinking the ''subaru scantool'' or whatever they call it, which does diagnostics and some programming of the computer. i didn't think / know it plugged into the OBD2 port. i don't even know if they still have them. but the connector in question looks kind of like one under my dash, drivers side, mounted onto the center console thingamajig / hvac / radio whachamacallit. those are technical terms. take a look.
scan tool connection maybe?? is it under the dash driver's side.?
did you replace the wire connector and the sensor or just the connector?? P0120 - Throttle Position Sensor Circuit Malfunction P0121 - Throttle Position Sensor Circuit Range Problem P0122 - Throttle Position Sensor Circuit Range Problem P0123 - Throttle Position Sensor Circuit High Input these code definitions are from http://www.troublecodes.net/Subaru/ , i really don't know if they are accurate. but i have no reason yet to doubt them.
try this tomorrow morning. shift into R and then just wait, do not put your foot on the gas. if possible maybe take your foot off the brake too. see if it clunks, or just engages slowly. or, back into your spot tonight and do your normal take off in the morning. see if it clunks going into D. the next day, back in and try shifting into D without any gas.
