9
are you takling about the ''keyway'' or the electrical parts? usually the keyway, the part you slide your key into is pretty easy to replace as long as you have a key. of course in the 8 years in between my car and your car they could have made it more complicated, theft proof. what are you trying to replace and why?
if my math is correct, the difference of 2/32 on a 185/70/14 tire is 0.19 inches which is within the 1/4" tolerance. but this math is theoretical. to be sure you need to measure the actual tires. i'd probably risk it if it is close. and keep the ''new'' tire on the front when you rotate until it wears down a little. (a year?) or if the actual tires do not fall into the 1/4" allowance, buy a second new tire and run the new tires on the left and the old tires on the right. or if it is an auto trans, put in the FWD fuse and keep the ''new'' 2 on the front for a year. this is not ideal, you run the risk of damaging the duty c.
just drive it and forget it. this will be hard to do with it clicking and reminding you it is there but give it a try. most shops will install a reman-axle. and some folks have had trouble with them right out of the box. i have one that was replaced last spring and one of the 2 is making noise now. i'm not sure if it is the replaced one or the older one. if you do your own work, or if your shop will let you buy your own parts, good re-built axles can be purchased at mwe. you will have to search to get the link. they are located in colorado and shipping will make them cost a little more than the ones at your local parts store, but they are better. a second alternative is to buy a used one and have it re-booted before you install it. but that will end up costing more than just swapping it out with a reman. but if you trust your shop and have a good relationship with them, just have them do the work and trust that they will re-do it if there is a problem. if they are trustworthy, they will not install a part that they know will cause trouble. they do not want the headache. they want you to keep driving your older car and to pay them to repair it when needed. so you can drive it in the snow and fix it when you can. eventually it will either lock up or fall apart and leave you stranded, but that could be a long time down the road. a napa reman-axle cost about 90$ (others are less) and the labor is about an hour, maybe more. so for 200$ - 250$ it's done. but i would not be surprised if they want 325$ to do the job.
probably not caused by the flat. and it usually takes a while for a torn boot to damage the CV enough to make it click. no problem driving it to the shop, 15 miles is nothing. some would say you can drive it 5k miles or more, but your wife, if she is like mine, will appreciate having it corrected sooner rather than later.
no vacuum associated with the trans cooler lines. there is a large vac hose under the plastic air intake that connects it to the pcv (on 2.5L cars any way). but usually the engine dies if that is open. it is hard to see. it is about the diameter of your thumb or larger. the pcv is on the passenger side towards the rear.
the 97 outback manual did not come stock with an ej22, it had the ej25 (dohc, count them). the 96 obw 5 speed did. so you might want to clear that up first. the 5 speeds from the 2.5L lego & outback cars 96 - 99 all have the same final drive ratio. so if the ''new'' 5 speed is from an outback it will bolt right in, no issues. if it is from a 2.2L car you will need the matching rear diff. the only other trans question is are the clutches the same, hydraulic vs. cable. i have no idea, but someone will. so what car is the donor engine coming out of?? ditto for the donor trans?
it sounds like you got the timing right. there is a link in my signature below to good pics if you have any doubts. my next guess would be a vacuum hose, maybe. wires might cause the crappy idle but not the rev-ing to 2k and back. double check all connections and hoses. did you get the fuel lines back on right? i have never heard of it happening in a subaru, but in small engines they will some times rev up just before they die from lack of fuel. is the plastic air box / filter and intake on correctly?
some folks have had the belt slip a tooth when installing it. i would double check that. also, if the crank pulley came loose, did it mess up the crank key way? or the crank sprocket key way? if there was any slop between the crank sprocket and the crank that could cause this problem. you say you used a new key, was the key way in the 6 oclock position when you aligned the timing marks? it is unusual for the loose bolt / pulley not to cause damage to the crank end / key way. it can be over come and corrected, but if the crank is ''one tooth'' off it will run crappy.
technically it has 2 fuel pumps, at least that's what subaru calls them, but really you only have one. it is on the passenger side of the fuel tank and does the work of sending the fuel to the engine. the other ''pump'' is more like a siphon, i hear, but i don't really know. it's job is to move fuel from the driver side of the tank over to the passenger side. (the tank straddles the rear diff.) any other symptoms of the car ''bogging down''.
heat
johnceggleston replied to 97ej22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
did you look on the floor? have you vacuumed out the car since the heat quit? where would it go if it dropped / popped off? -
ej25s 96 - 99 are prone to internal head gasket leaks. some as earlier as 60k, most in the 100 - 200k and a few later than that. i have swapped out two ej25s, one at 142k and one at 148k. i drove one ej25 from 98k to 139k and it's gaskets had been done before i got it. and i have one waiting with 152k. so you get the idea. but there are plenty of them for sale with bad gaskets now with 200k+ miles. the 00 - 03? ej25s have external head gasket leaks, less often, i think. this is slightly better. you can see the leak and since it doesn't cause overheating until the coolant level gets low you can continue to drive it as long as you keep the coolant topped up. (internal leaks can cause overheating by displacing coolant in a single drive cycle when sever, or by causing a ''vapor / air lock'' which keeps the coolant from flowing properly.) the only way to be sure about a car with an ej25 when buying is to have the HGs done or have a warranty which includes head gaskets. usually when the gaskets are replaced correctly they do not re-occur. there is lots of info here to read about them. start with the link below and then search on from there if you are interested. http://www.ultimatesubaru.org/forum/showthread.php?t=104353&highlight=badheadgaskets
i don't have a problem with state inspections. if it is bad enough to fail it needs to be replaced / repaired. i do have a problem with shops who tell me it will cost 450$ to fix what the car needs to pass only to learn when i go in and look at everything that the service writer''mis-spoke'' and he mis-understood the technician who actually did look at the car. it only needed front pads. that's just wrong, and it happens every day. it does seem unfair to have to buy a new windshield for a 90 nissan pickup when i only drive 1500 miles a year. but if i want to drive it on the open road in VA that is what i will take. the last time i needed a windshield i shopped and got it installed for ~100$.
