8
first i'm an auto trans guy , so i may be wrong on some of the finer points. but... you need to tart over. vss #1, on autos, has nothing to do with the speedo / odo. so check your cel code again. on 5 speeds, the vss #2 is on the passenger side about half way back, i think. on autos, the vss #2 has a wire connector built into the top of the unit. so the wire harness plugs right into the speed sensor. check it again, unplug it and plug it back in again. not working except when you hit a pothole sounds like it could be a lose connection, or maybe the speedo drive gears. but lets not go there yet. Vss#1 is on the rear extention housing, passenger side, again auto trans, and there is NO wire connector at the unit. it is part of the trans harness, which the manual trans does not have. edit, manual trans do not have this one. pic below, from an auto trans, vss #1 is on the left and #2 is on the right. if yours looks different, please disregard everything i said. EDIT: maybe check the connector at the speedo.
if it is really water on the plug, then that cylinder is not firing. it would cook off pretty quick, wouldn't? RIGHT? new plugs, wires, air filter, oil and filter, check the coil, replace the fuel maybe. mine made a racket when i swapped it in, after 30 months sitting. it ran ok but it made a lot of noise. i just let it idle for a long time. i had nothing to lose. the swap was done, it was going to be a good engine or it wasn't. worrying was not going to change the outcome. but revving it might.
if you check out item #12 in the pic, you'll see the the dip stick takes an almost 90* turn before it enters the oil pan. it is then closer to horizontal than vertical when it enters the oil. so yes, 1/4 qt of oil makes a big difference on the dip stick. http://opposedforces.com/parts/legacy/us_b11/type_45/lubrication_system/oil_pan/
no you can't run the engine with the flex plate unbolted from the TC. unless you have another way to start it. the starter gear engages the teeth on the TC which is bolted to the flex plate and the crank. if you unbolt it, the crank will not turn when you turn the key. the question you need to ask is, if not the flex plate, then what? how bad is this "knock"? what if you just drove it as is? if it is internal it's cheaper to replace than to repair, generally speaking unless it is just valve noise. and if it is the flex plate it will get worse over time, then you will know.
you really will be hapier, more confident with a haynes manual at your side. they are not perfect but they are handy and they do have the torque setting listed. a couple of notes on this whole process (there are lots of good write ups which you search for and read): 1. if the engine is out of the car and it is an auto trans, search and read "torqueconverter" (the oldest thread) before you reinstall the engine. 2. a few of the torque setting are correctly listed in INCH/LBS. not ft / lbs. do not over torque anything. you do not want to bust a bolt or strip out threads. there is one exception, see item 3. 3. the crank pulley bolt should be torqued to at least 125 ft/lbs, i use 140 ft/lbs. if you do not it may / will work loose over time and mess up the key way. there are lots of subies for sale with "boogered" crank shaft key way and pulley. is the engine in or out of the car? i would test thread all of the head bolts before the actual install. use some oil or lube to make them work easy before you try it with the heads. i have a parts car i bought for 200$ because a head bolt was cross threaded and busted. an extra pair of hands helps when setting the heads. NO SPRAY on the heads or gaskets. how many miles on the car, did you say before? auto or manual?
check the pics on page 2 in the second link below. the crank sprocket has a line or hash mark on one of the reluctors or tabs on the back edge of it. it goes in the 12 oc'lock position and line up with the mark on the timing cover or block. (the key way will be in the 6 o'clock position.) the cam pulleys als so have a line or hash mark on the front outer edge of the pulley. they go in the 12 o'clock position and line up with the mark on the rear of the timing cover. some timing belts will come with corresponding marks on them which may or may not be correct. if you plan on using them you should double check the tooth count. which i do not know off of the top of my head. i'd have to check my haynes manual. but regardless, as long as all 3 timing marks are in the 12 o'clock position, you will be good. after several rotations, they will all still be in the correct positions, BUT the marks on the belt will not be. take care in compressing the tensioner.
i have no idea what you are trying to do , but i do know this: 1. your engine is non-interference, valves cannot hit pistons. 2. set the crank sprocket to the correct timing mark and all of the pistons will be at the mid-cylinder position. 3. assemble the cam shafts, rockers and cam pulleys and install. rotate to the correct timing mark and hang the belt. timing will be right. except for arrows on the pulleys that are NOT used for timing the engine, common mistake, subaru has made it easy. so easy in fact that i can do it and get it right on my first try after a 30 year wait since i adjusted a valve. i think you are trying to make something simple, into something difficult.
if this is a new to you trans you have no way of knowing what they did to it during removal. even after draining the pan, tipping the trans front up can drain the TC and or drain fliud out the rear. personally, i would fill to the cold full line with the engine off. then run it to circulate the fluid throughout the trans and re-check it. there is little chance it has enough fluid if it does not have enough when sitting still and cold. the volume actually increase when hot but not a lot, 1/2 a pint or so. so if you get it close cold then you can tweak it when hot and running. the dip sticks are hard to read, the red fluid appears clear on the stick, look at both sides. someone mentioned that an ice cold dip stick, placing it in ice water, made it easier to read but i don't know.
for the trans, you might try some Trans-X additive. others have had good luck with it in 99s. from a couple of recent posts it seems that earlier is better for stopping the "slow to engage" in the 99 auto trans which is a known problem. search "trans-x" and read up on it. there is an especially long thread with success stories.
yes. the months probably aren't as hard on it as the miles but the risk is just too great to not have it done. however, my question would be do the idlers age the same as the ''rubber" belt itself? how about the water pump? regardless, when doing a timing belt, the question you should ask in regard to replacing components is "will this part go another 105k miles?" if you have any doubt, it should be replaced.
