9
it sound like the clips that the brake pads ride in are missing on one side and this is letting the pad move around and causing it to wear incorrectly. i have never seen brake pads in a caliper without the clips top and bottom. i think this is VERY DANGEROUS, mostly because i just don't know what might happen. buy pads and clips for that side at the least, both sides would be better. even cheap, 18$ pads with clips would be better than no clips. you can re-assess in the spring. or, buy as much insurance as they will let you buy.
i had/have a similar problem on my son's 95 lego. sometimes the car would have binding and sometimes the fuse world cure the binding but neither would happen all the time. i never figured out if it was the duty c it self or the wiring or what. i suspect that heat had something to do with it. check the wiring connector going to the trans, undo it and snap it back. the TCU is pretty easy to swap out. pretty much any similar year will work, some of the mounting cases are different but the boards inside are the same, physically and plug right in. we ended up removing the rear section of drive shaft until we could replace the duty c, real fwd, but we haven't done it yet, 2 years.
yes, the bottom one is a nut , it takes a 17mm socket. the top one is a bolt, it takes a 14mm socket. metric bolts and nuts are defined by several measurements diameter of the shaft, 8mm, 10mm, 12mm etc, and the threads, how coarse or fine, 1.00, or 1.25 for example. the threads of the nut are the same as the top bolt, either 1.00 or 1.25. the diameter of the nut MAY be the same as the bolt but it could be one step up or one step down. but the thread 'count' is the same. go to the hardware stoore and find a nut that fits the top bolt, then also get one size, read diameter, larger and one smaller. you probably won't need the smaller one, especially if one of the other 2 takes a 17mm socket. don't forget the washers, one flat and one lock type. three nuts and 6 washers may cost you 5 - 7$ but but should save you the time of making a second trip. oh yeah, about the time you get the new nut tightened up, you will no doubt find the old one.
when draining the trans you get about 4 of 9 qts of fluid. if you jack up the front of the car you can get more out. so if the TC tips it can spill fluid even after you drained the trans. i don't remember having this problem but who knows. if this is your first auto trans, there is a long shaft, 24"?, on the inside/back side of the TC. so it won't fall off, but it will tend to stay on the motor until you get about 1/2 - 3/4 inch of seperation, then it is clear and should stay put. you will want to read up on seating the 'torqueconverter' (search that). you do not want to run the risk of installing one incorrectly. and since you will have a bad one to practice on, take advantage of it. it is not really hard to do, you just need to know it has to be done. the above search string will give you great pics and a good how to.
i too am clueless, but i read here not too long ago, and i believed it, that all sun roofs leak!!!! the reason they work is because they have a water disposal system in place to take care of the leaking water. everything leaks, roofs leak, pipes leak, windows and doors leak air, boats leak, even head gaskets leak. how can the auto industry invent / engineer a glass/rubber?/metal seal that does not leak ??? only the space shuttle doesn't leak, at least not very much. i know you said it wasn't the drain tubes, and that the whole thing needed to be replaced, but ....... i think i'd study it a lot before i bought all new parts. the HVAC industry has a great foil backed rubbery sticky gooey sealant tape that they use on duct work, no not duck tape, that is pretty impressive stuff. i used some on a rear hatch where i remove a spoiler and it is still dry 2 years later. but i'm sure it is very costly for a whole roll. i first used it when i pulled an engine i was going to store to seal up openings and tubes. when it came time to install it i had to use a solvent to remove all the adhesive.
my understanding is that the actual crank sprocket timing mark is NOT on the front face of the sprocket but on the rear "tabs". and your picture doesn't show that detail. the other telltale is that the crank keyway is down at the 6 o'clock position. there are some great pictures in a link in my signature below, the ones you want are on page 2.
we don't get enough snow to be able to say that abs is the problem. but i can say with certainty, during the last snow, 16", i had much more control of the car going down hill in 1st (auto trans) than i did when i put my foot on the brake. the tires were grabbing when in gear, all 4 by the way, and i could slow down and drive. as soon as i tried to come to a complete stop , with the abs, it became more like a sleigh ride. i didn't know enough to put it in neutral. i'll have to read my owners manual to see what it recommends for snow and ice. i don't remember any warnings or suggestions regarding abs, but then it's hard to read and drive at the same time. and there was one stop light and hill combination that had me worried. i figured out a plan as i was not slowing enough and then i stopped. but then i worried about the guy behind me and started looking for somewhere to go just in case.
edit: gary types faster!! 99s have a history of bad speedos. if it was a different year i would have guessed the speed sensor, but not for 99. you can use any outback speedo 96 - 99, maybe legacy too, but outback would be better. extra points if you find one with similar mileage. post an ad here in the classifieds wanted section. some one should have one on the shelf. or look here: www.car-part.com sort your search by distance.
most folks just use a stout screw driver or socket extension in the access hole up top. just don't drop it in. this didn't sound right to me so i used a chain wrench on the crank pulley using old accessory belt to protect it. this worked, but i hear it can stress the pulley, the rubber piece can fail and separate. and this one i'm not too sure about, someone who has lots of posts has posted that there is a hole part way down on the bell housing and a screwdriver there will work, I THINK, i may have mis-understood. this didn't sound right either, but i haven't even looked for a hole there yet. the actual tool is y shaped or u shaped with 2 prongs for the holes in the crank pulley and a long handle. the y or u allows you to access the bolt in the center. basically a breaker bar with 2 prongs instead of a socket.
i'd trust the interchange software at the used parts yards. they are very conservative, not likely to make a mistake that will cost you or them money. and as one yard owner told me after i commented that all 90 - 99 front axles were the same, "we pay a lot of money every year to know what fits and what doesn't." he was offended that i challenged his software. if it is an outback, not impreza, it's going to be a 4.11 manual or 4.44 auto. a legacy L may be 3.9 and 4.11 respectively, but since they both have the 2.5L engine (no more 2.2L engines) i may be wrong about the legacy ratios.
if your oil pan gasket is leaking it will be the first one this year. meaning, they don't leak often and you have to lift the engine to get to all the bolts. if the rear of the engine is oily and it looks like the oil pan is the cause, it is probably the oil seperator plate on the back of the engine behind the fly wheel. but you have to pull the engine to get to it, so most let that one go unless it is really bad or you are pulling the engine for some other reason. valve covers are pretty easy, make sure to get the rubber grommets for the bolts. this is a common leak for legacys. fix it first and then see what else you need. there is a chance that the bolts are just a little loose, snug them up and maybe.... another common leak point is the oil pump, either the o-ring behind it or screws on the impeller. crank seal and cam seal & o-rings,... but valve covers first. the cam & crank seals may be needed just because of their age but if they aren't leaking bad i'd wait until 120k t-belt change, unless that's 10 years away. you have to remove the timing belt to do the oil pump, cam and crank seals. so if you choose to do them now, do all of the timing parts as well. how many miles a year do you drive??
