9
it's probably a vacuum hose. look under the air intake tube, big 4" black tube , about half way between the air filter and the 'air box' at the rear of the engine. the hose will slip off when the air filter box is opened and cause the car not to run / idle correctly. _ _it happens. you alternator may not have been bad, but who knows.
the miles plus cost is very attractive, 34,000 plus 10000.0 = 134. by my standard the is the same as a subaru with o miles for $13,400 or a car with 100k miles for $3,400. the bigger question is affordability. does it fit your budget.? and this car even with only 34k miles is going to need a timing belt soon, around 2012. the t-belt schedule is 105k miles or 105 months. the cost of the t-belt will range from 500 - 1000 depending where you live and how much you do. this engine, any 2.5L and any 2.2L '97 - '01, will have expensive damage if the timing belt breaks. personally i'm crazy about the 95 or 96 legacy for a reliable high mileage used car. and if you only drive 4000 miles a year, a 95 with 180k will last you a very long time. it's not bad looking, the engine is non-interference (no damage if the belt breaks) and as mentioned before, parts are readily available. but you will have to add some repair cost to the purchase of what ever used car you buy. almost none will be in perfect working order. i read an article in AARP magazine recently which made 2 great points, maintaining the car you have is almost always cheaper than buying "new". and, the average age of a car in america today is 9.3 years. mine (90, 97, & 95) are on the high side, but there must be some really old cars out there. if your dodge is still serving you well you can take your time and wait for a great deal to come along that fits your budget. good luck and let us know what you do.
the fuel tank holds 15.9 us gallons. usually my light comes on around 13.5 gals (97 GT) to 14.2 (97 outback). set your trip meter when you fill up and you will start to get a feel for how many miles are in a tank and how many gals you have left. the fuel gages ( fuel gage sending units actually) are notoriously inaccurate. they hit empty at ~10.5 gals spent. you can use thechron fuel additive and it may help. (my 95 after sitting for months didn't register a fill up at all, a bottle of techron got it working like yours is.) used fuel senders are cheap but very likely to be the same as what you have. new ones are expensive.
there is really only one question regarding these two trans, do the final drives match? the internal gearing is the same. i think the impreza trans number is a typo, should be TZ102Z3ABA, not ...Z3A13A. research the fnal drive for the corresponding cars and i'll bet the part numbers match. look here under "train" when you see it.: http://opposedforces.com/parts they appear to be the same, 4.11 final drive. http://opposedforces.com/parts/legacy/us_b11/type_6/train/differential_individual/illustration_1/ http://opposedforces.com/parts/impreza/us_g10/type_24/train/differential_individual/illustration_1/
actually i think it was 30, but what ever. they are still $.50 each, plus shipping. i don't know where you buy them, but at advance auto parts they are $1.79. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Oil-Pan-Drain-Plug-Gasket-Motormite_17190165-P_797_R|GRPFILTAMS_160555891___
because you are new, you don't know this: the 96 - 99 2.5L engine had a head gasket problem. the reason the previous owner replaced the engine was probably because the first engine had bad head gaskets. he put in a low mileage replacement which now has bad head gaskets. depending on where you are, the gasket replacement cost 900$ - 1500$. USE ONLY A SUBARU GASKET!!!!!!! others will fail shortly. the other solution is to swap in a used 2.2L engine, those did not have the HG problem. keep us posted.
if you are selling it it does not matter, the belt is good. now you may be able to get some consideration from the shop in the future. but think of it this way, how many car salesmen are going to ask "WHY" when you walk in and say you want to buy a car. yes mechanics are different, but still there must be some owners who don't drive over 55 and who change there oil at 2000 miles. if you order a timing belt you get a timing belt. that's way better than paying for one and not getting it. and now you get to sell your car and not feel guilty about it needing a belt or having to pay for the service now.
