				Posts6699
				Days Won9
	now only one more thing to be sure of before the swap. how to seat the torque converter correctly. it's not hard to do if you KNOW it needs doing, but first timers often do not 'seat' it completely and end up DESTROYING their new trans. so read this. http://www.ultimatesubaru.org/forum/showthread.php?t=81925&highlight=seat+torque+converter and good luck
	this is news to me, learn something new every day. i put a 96 trans in a 95 with no trouble at all. i don't remember the part numbers but every thing was a perfect match. and i know 96 and 98 are the same, lots of those swaps have been done. i guess early 95 was more of a 94. EDIT: did you check both connectors on the rear of the engine? one is for the trans and one is for the engine. sorry to be so dumb, but 99 was the first year i had ever heard of wiring change, but i don't do 90 - 94 stuff and i just trying to learn this right.. good luck
	dash, there is a good chance that the speedo will not be accurate after the swap. be careful until you know for sure. the speedo drive gears in the outback front diff are different than the the legacy so there will be an error. it may be very slight , but kids tend to push the limit and no body needs a speeding ticket.
	just my opinion, i would get this engine running as perfect as practical before you make the swap. once swapped you will have a good idea of how it should run. hopefully you will be able to tell what problems were there before and what, if any, were caused by the swap. it may make things easier to diagnose.
	i think with a little research and a couple of phone calls you can find out for sure the gear and final drive ratios. i would not do it without confirmation. these 3 links seem to indicate it will work. http://opposedforces.com/parts/legacy/us_b12/type_28/automatic_transmission/at_transmission_assembly/ http://opposedforces.com/parts/info/31000AE330/ http://opposedforces.com/parts/info/31000AF780/
	all oils today have detergents in them. i have read, here, that the best way to clean your engine inside is to change the oil more frequently, 1k instead of 3 or 2k instead of 5. this gives the detergents a chance to work before the oil starts to break down and leave stuff behind. i don't really know, any truth to this??
