EJ22 HGs... to replace or not to replace?
how many miles a year, 15k, 30k, or more? i wouldn't touch the hg unless it is blown. depending on the t-belt you use you'll be good for 60 or 100k miles.
Changing Timing Belt
johnceggleston replied to PetterFan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you don't have a haynes manual you will regret it. top of engine, passenger side where the engine meets the trans. right next to the throttle body.
Legacy GT
johnceggleston replied to Sushi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdifferent on GTs, late 90s: 2.5 engine (sane as outback) trans (sane as outback) wheels, different look but tires are the same diameter as legacy sunroof power antenna bumpers, front and rear (and rocker covers ) rear sway bar same on GTs: struts axles seats interior maybe different: tach cd player roof rack Vlsd was available around 02-03 in outbacks and canbe bought from salvage yards for ~100$. if you put GT wheels on a brighton, it will look like a GT. it will not drive like a GT.
My Legacy 2.2 has started interfering??
johnceggleston replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you removed the crank sprocket to see if the key way is good on it and the crank?? interference engines will 'interfere' by definition, what is screwy is this one is interfering when supposedly 'lined up' for a new belt. what if you turned the cams 180 degrees and the crank 90 degrees, hang the belt and then turn it over by hand looking for interference.
Just wanted to replace a ball joint, but the axle pulled out!?!
johnceggleston replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've never taken one of these apart, but from the diagram in the haynes manual there is supposed to be a "ring clip"? on the end of that shaft. it either popped off or pulled through whatever the shaft fits into. i can't imagine the clip bears a lot of force when driving since the inner doj has 'slip' (inboard / outboard) built in to it. but if the inner were to freeze up then the outter may in fact slip out while driving. loosing power in one front wheel at speed would probably not be fatal, but certainly inconvenient and maybe damaging to nearby stuff if the half shaft was flopping around under the car.
pulls right by design?
johnceggleston replied to turin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy only comment would be not to condemn the car or the alignment based soley on the ride home from the dealer. i assume you have 'test driven' this car extensively, and find the car lacking. so be it. when ever i get my car back from an alignment i'm always skeptical of the 'pull'. but when i drive it on the interstate, it pulls to the right in the right lane and to the left in the left lane, due to the crown in the road. that's as good as it gets. good luck with the car. i hope you can find a good solution.
johnceggleston replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe the 96 2.2 was really a 97??????
Wheel bearing preload set by axle nut?
johnceggleston replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm going to play dummy here, not hard for me. the nut may not do any thing to set the bearing properly, but it certainly does do something to protect the bearing when there is a load on it. what's the difference?? there must be a very fine line between the two.
Rear window (not Alfred Hitchcock)
you can't do it unless you use a rock. seriously, the window can't go down any more because of the 'cut out' for the wheel well. the door is narrower at the bottom than the window is at the bottom.
johnceggleston replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think the outboard CV joint came apart.
Transmission issue...not enough fluid?
i don't think i'd do this. you know now roughly how much you drained, i'd fill it with 3.5 - 4 qts and see how it does. you do not want to risk running the car with the fluid low again. i'd get it as close as possible w/ cold fluid and the car off, and then check and adjust it with the fluid hot. you can always drain and fill again next week. if you read the dipstik before you fill it, and it looks like it's full, ignore it. it is low regardless of what the dipstick says, they are hard to read. add fluid. i ruined a trans because the idiot who replaced the rear trans seal failed to add fluid. he said "the dip stick read full". i added 4 qts the next day and i lost the trans, reverse first. i have read here that ATF is one of the few fluids that will improve functionality even if you only change part of it.
Bought another Subie, but it's missing some parts...
johnceggleston replied to Cowgirl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi doubt the timing cover gasket is critical, at least i hope not since i'm not using one. the crank pulley bolt should be easy to find, some one here should have one or even from the dealer it shouldn't be too bad. ( part number - 800213030, $3.50 online plus shipping; retail at the local dealer - $4.50) but someone has one.
the dip stick for the ATF is about 2 feet long, the dip stick for the front diff is about 2 inches long. the diff is on the passenger side and the ATF is on the drivers side under the ac lines. check them both.
how much fluid drains out depends on how high the front of the car is. if it's level you get one amount, if the front is higher, you get more. where did you add the ATF? check the dipstick on the other side of the trans. this really sounds crazy.
i think the manual said 2.75 gals, that's 11 qts, but when you drain it only 3-4 come out. check it when it's cold with the engine off just to see if you are in the ballpark. you are probably low. low can cause damage. add some to get it close and then check it hot engine running. the dip stick is really hard to read when the car is running.
My Suby is marking its Spot
johnceggleston replied to JGromada's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvalve cover gaskets and spark plug grommets, this is pretty easy to do. cam shaft seals, crank shaft seal, and cam cap o-rings aren't hard, but you have to remove the timing belt to get to them so you do all of them together. the oli pump seal/o-ring and backing plate screws, if these are leaking there would probably be a puddle under your car, do this with the t-belt as above. oil seperator plate on the back of the engine behind the fly wheel / flex plate, you have to pull the engine to do this one and you buy a new metal plate and NEW screws and replace the old plastic plate. where is your oil coming from, the front, the bach, up high, down low?
johnceggleston replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi had one do this, there is a clip on the splined end of the shaft that slides into the outer joint thingy? i couldn't get the axle out of the hub and i was removing the hub to take it to be pressed out, and the axle shaft popped out of the joint thingy. i swapped the axle out. the boot was torn when i bought the car and i saw no reason to reuse the axle. better safe than sorry. i guess if you cleaned it up and put it back together it might be ok.
heated side view mirrors
johnceggleston replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi took 2 broken mirrors and made 1 good one, but i don't remember how i took them apart. i think there is a screw or screws near where the wires come out, undo it and the works will slide out of the housing. or maybeyou have to remove the glass to get to the works/screws... i can't remember. if there isn't a screw, then use that diagnostic hammer you keep in your tool box.
Impreza Electronic Mirrors don't work
johnceggleston replied to myhilo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere should be another fuse panel under the hood near the drivers door.
1997 Outback Sport Impreza - Sad Tale
johnceggleston replied to Balewolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'd start by posting a 'wanted' ad here on our classifieds. and then i'd look here: http://www.car-part.com sort your search by distance, you might get lucky.
99 forester hub questions
johnceggleston replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe hub assembly is universal as long as it matches your abs system, meaning i think a 92 legacy would work except for the abs sensor hole. these are rears, fronts crossover the same. item 2 or 3 here: http://opposedforces.com/parts/forester/us_s10/type_3/suspension_and_axle/rear_axle/illustration_1/ click on usage here: http://opposedforces.com/parts/info/28411AA000/
TY752VA1AA transmission - The mystery is gradually clearing up!
johnceggleston replied to casm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi had a thought. the trans on the chart with the same ending characters was the TY754VA1AA. this was the first of the 754 series of trans and was used in the 99 or 00 impreza with the ej22. it stands to reason that the TY752VA1AA was the first in the 752 series of trans. probably as you have already said 90 or 91. did they make the impreza that early? was there a 89 legacy ??
'05 Impressa automatic
johnceggleston replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso if i throw away the doors, gut the interior and cut off the roof and put on a canvass top maybe mine won't blow.
johnceggleston replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes this mean, a96 - 99 impreza 2.5L dohc replacement engine is a better choice than an outback ej25??? i don't follow imprezas so i'm not as familiar their problems.
johnceggleston replied to casm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis it in the car? i'm willing to bet it's a 3.9. one of the other fourms had a list of all trans, manual and auto w clutch type , grar ratios and final drive ratio. i lost my book mark when my laptop died. but someone may remember. my limited understanding leads me to believe the following: i don't think the 4.11 was available in the manual trans until the 2.5L engine came out, but i don't do 90 - 94 so i can't be sure. the 3.7 in legacy was generally reserved for FWD cars, the same make and model AWD would have the 3.9. based on my limited knowledge and open to correction. try this, put it in 4th gear, turn the input shaft 39 or better 78 times and count the output shaft turns, it should be in the 10 for 39 or 20 for 78 range. you can use a piece of string taped to the shaft as a counting device. if it's in the car just jack up one rear wheel and turn it 10 times. count the number of turns on the rear drive shaft. was there an ...."A1AA" on the chart? that should be the same model and year car.
