9
the hub assembly is universal as long as it matches your abs system, meaning i think a 92 legacy would work except for the abs sensor hole. these are rears, fronts crossover the same. item 2 or 3 here: http://opposedforces.com/parts/forester/us_s10/type_3/suspension_and_axle/rear_axle/illustration_1/ click on usage here: http://opposedforces.com/parts/info/28411AA000/
i had a thought. the trans on the chart with the same ending characters was the TY754VA1AA. this was the first of the 754 series of trans and was used in the 99 or 00 impreza with the ej22. it stands to reason that the TY752VA1AA was the first in the 752 series of trans. probably as you have already said 90 or 91. did they make the impreza that early? was there a 89 legacy ??
is it in the car? i'm willing to bet it's a 3.9. one of the other fourms had a list of all trans, manual and auto w clutch type , grar ratios and final drive ratio. i lost my book mark when my laptop died. but someone may remember. my limited understanding leads me to believe the following: i don't think the 4.11 was available in the manual trans until the 2.5L engine came out, but i don't do 90 - 94 so i can't be sure. the 3.7 in legacy was generally reserved for FWD cars, the same make and model AWD would have the 3.9. based on my limited knowledge and open to correction. try this, put it in 4th gear, turn the input shaft 39 or better 78 times and count the output shaft turns, it should be in the 10 for 39 or 20 for 78 range. you can use a piece of string taped to the shaft as a counting device. if it's in the car just jack up one rear wheel and turn it 10 times. count the number of turns on the rear drive shaft. was there an ...."A1AA" on the chart? that should be the same model and year car.
i have had some luck turning the engine by hand while feeding the belt on. on a side note, when i did my engine swap i failed to tighten the alt/ps belt enough. it would squeal at start up and tight turns. i finally thigtened it , but now, 3 months later it has an occasional squeal. i'm a little scared of making it too tight. (i have an alt on the shelf because the threads in the body stripped.) any one have a rule of thumb for how tight to make it???
to the op, there is a small chance that the valves are not bent which is the usual damage for broken t-belt on a 97 - 99 ej22. but you'd have to hang a new belt to see, plus replace any damaged idlers, tensioners, or water pump. but with that many miles, a replacement is your best choice. you might get lucky and fine a 95 ej22 from an auto trans car, it would be non-interference and bolt right in.
IIRC, there are 4 bolts engine to trans left top and bottom and right top and bottom. there is the dog bone up top right behind the throttle body and there is a rear trans mount/ support. plus wires and shifter cable. the driver side lower trans bolt is a b**ch. no easy way, you just keep at it. driver side top, you remove the starter, one of those is a trans bolt the other is a nut on a stud. but the starter must be removed, i think. i don't really remember the passenger side so i assume they aren't too hard to get to. dogbone is easy, but with it and the trans gone, the engine may want to flop around a bit, so be careful. i usually pull the engine not the trans. the rear trans mount, i removed the 2 bolts on the cross member leaving it attached to the trans just cause it was easier to get to. there may be more i'm missing, but this is what stands out in my mind. some one posted a pretty good write up on a trans jack / support / lifting type thing. you might look for that. careful not to dent the oil pan, it can damage the wires inside. this is an auto trans, right? please correct me if i'm wrong.
no offense to dave, he's tackling a job most people would pay 600 - 800$ just for the r & r not to mention the repair, but this remids me of my first , and last, attempt to take apart an alarm clock. i got some things off, but got nowhere near the complete job, not to mention the repair. dave, slow down, do a lot of reading, spend 15$ on a haynes manual if you have not done that yet and search for the great trans removal descriptions that have been posted in the past. then read and re-read them until you know them. i usually have to hand write the descriptions for it to sink ino my brain. it makes for very slow going, but once i have it i can almost visualize it when i'm under the car. keep reading and asking, then take the good advice given and you will get there. just my opinion, no offense intended. i just hate doing things twice.
stop, wait!!! maybe you need to replace the the HGs again, but that is useless until you figure out what is causing your problem. better to figure it out now than to do all the work again and still have problems. i'm no pro, but i think it would have to be a pretty odd situation that causes your problems, just because of an off brand head gasket. usually the off brand gaskets fail sooner, not fail imediately. but i could be wrong. if it is not the timing belt, what might it be?? what are the symtoms again, ok at speed, rough at idle??? if you are 110% sure the timing belt is right, (btw: posting pictures would help convince the rest of us), diagnose the problem from scratch, disregarding the belt. lot's of stuff gets undone when gaskets are replaced. maybe there are other things that could cause these problems. i recently remember a problem caused by a couple of vacuum hoses being swapped. what else might cause this this problem.??
IIRC it's 1+1/4 inch, but that's almost a guess. but before you undo that nut, which is 'staked', bent, if you undo the strut bolts that connect it to the hub assembly, you may not need to do the axle nut. the stru to hub bolts are not 'gross' tight bolts, spray them and use a 24" long 1/2" breaker bar. mark them before you remove them. flop the hub outward, pull the axel with it and slide the trans end of the axle off of the trans stub.
i'm not sure i understand completely but..... two of the receiving buckles are bolted to the car in the same place making it easy to mix them up. and for reasons i don't understand, the middle seatbelt is different than the side seat belt so you have to make sure you are using the middle belt and receiver for the middle and the side ones for the sides. if you are missing a receiving buckle or a belt, look under the seat, it folds forward. reach in between the seat and the back and feel around for a pull loop. usually seatbelts will extend and retract as often as you want when you want, but some / all have a child seat safety feature built in, if you pull the belt out all of the way before you clip it, as it retracts it locks and will not extend again until it has retracted all the way or so. if you can release the clip from the ceiling? and let it retract all the way back in you should be able to pull it out again. i hope this helps.
