9
i want to add to my "heated" accessories switches so they go off with the car and do not come back on with the car unless re-activated manually, like the cruise control. i want to put it on my rear defrost, heated mirror and seats. i'm sure i'll need a relay but i need one that will keep the switch on only as long as it has power, then default to off. what kind of relay? hard to do? safe to do? what do you call it? what parts would you need? another option might be to add a timer to the circuit, on for 5 minutes or what ever. thanks, john
in the pic above, on the new style there are 'tabs' that aren't on the old that stick out from the edge of the head. look at the corners, and the other end of the oblong openings, on the right side of the new gasket. my only question is are those tabs on the top side or bottom of the engine when assembled.
Newbie needs help.............96 outback
johnceggleston replied to dharper's topic in Subaru Retrofitting
since you have both cars, use the 2.2L power steering lines with the 2.2 engine in the 2.5L car. it will look cleaner. the 2.5 lines will work, but won't fit the support bracket. let's review, so that's: 2.2L engine, p/.s lines, y-pipe, and ecu 2.5L flex plate (fly wheel), and car -
5SPD D/R transmission into '92 Loyale project
johnceggleston replied to cmiller's topic in Subaru Retrofitting
yes the 4 spd d/r, 83 - 87, i was just looking for the low range, off road. how different are they? the gear ratios appear to be close. is the loyale too heavy? mostly i was wondering about the bell housing bolts. what kind of mods besides the hi low lever, trans mount, shifter? is it possible/ practical to swap the 'dual range' section on to the loyale 5 speed?? -
IIRC, for auto trans, vss1 is on the rear extention housing on the rear of the trans, pass side. vss2 is pass side about 1/2 way down from the top near the fire wall. wiring for the rear goes through the large trans wiring connector above the vss2, front sensor, on the trans bell housing. check the connection pins, odd that both failed.
i think it's in the 28 - 32 ft lb range, but i don't have my haynes manual with me so you will need to double check that. also, at least one is really tough to get to with a torque wrench so i just matched it by feel to the ones i torqued. you can always go back and tighten them, but it's a real b!tch if you strip one out.
not the speed sensor, it's dumb, the TCU. the speed sensor rotates with the wheels the TCU does the math. neither has to consider the final drive ratio since the sensor is after the final drive. borrow a tcu from an outback. yes, using a tcu from an outback should help correct your speedo / odo. if my math is correct, the difference between the legacy auto 4.11 and the outback auto 4.44 final drive ratio is about the same as the difference between the tire circumferrenc. in other words, when they made the rear diff 'more powerful' with lower gearing, they put on larger tires and offset the gearing reduction. now the GT has the legacy tires and the outback final drive ratio, making it more powerful and quicker. by putting outback size/diameter tires on a legacy you will throw off the speedo, the outback tcu will help correct it. the drive gear in the front diff that drives the speed sensor turns with the ring gear/axles not the pinion. the gear reduction has already done it's thing. the TCU just does the math, X wheel revs per mile; wheel rev per minute = mph. larger tire size increases the distance traveled for each revolution and reduces the number of wheel revolutions in a mile. you're right about swapping the final drive gearing, and it re-compensating, power-wise, for the larger tires. you would come closer to the original power curve but still limited by the 2.2L engine. is there a significant difference in the power curves for these 2 engines?? want your outback to drive like a GT, put on GT / legacy size tires and swap in a GT tcu. want your GT to drive like an outback swap the tcu and tires. as stated in numerous other threads, there is not a dramatic difference when you swap larger tires on a legacy but there is the speedo/odo difference. just my opinion. any thoughts? ps: this is for late 90s cars.
will an 83 - 87 dual range trans bolt right into a 91 loyale 5 spd?? i have dreams... thanks, john -
i understand your problem and it sounds like you have hit your limit. but you need to answer 4 money questions before you change cars out of frustration. 1. what will it cost to fix this car? 2. what can you sell this car for? 3. what will it cost to buy a different car? 4. which is cheaper? it's not a question of is the car worth the repairs, it's a question of how much per mile?? they phased out the 2.2L around 2000.
if it is a hg leak, it must be pushing coolant out into the over flow and eventually,. once the 'air bubble' gets big enough, NOT sucking it all back in. try running it with no coolant in the overflow and see if you get some. not very scientific but logical. or drive it on the hiway, get it up to temp, and then let it idle in the drive way. my rad cap was bad and only leaked at temp. this is how i found it. if you have a leak, it may not show up untill it's warmed up and you can't see it at 60 mph. as the car cools off it willleak less? will a pressure test check the cap? i take it there's no gook in the over flow, or smell like exhaust gas.
