9
i can't be specific about putting the torqur converter on to the trans, because i've never done it. but some one posted it would be a good idea to measure the distances from the TC to the trans/diff befroe you disaessemble it so you know what to shoot for when you put it back together. you'll have a reference point. sounds like a good idea to me. on another thought. for 335$ i'd probably pay the guy ot install the trans for me. of course there's the ATFluid and the seperator plate replacement on the rear of the engine to add in if it hasn't been done. just a thought.
the TZ102Z2DBA is the model number, you just need to confirm that it is the trans in your car. meaning someone didn't swap it as well as the engine. so if the model number on the trans is TZ102Z2DBA, as the id tag indicates, then the 2 model numbers posted above will work without any issues. when talking to salvage yards, they are going to ask for year, make, model, and/or engine. (98, subaru outback, 2.5L) their software will return 97 - 98 trans with those 2 model numbers. giving them model number will not help them find a match and may only confuse the issue. but you can have them confirm the model number on the trans before you buy or have it shipped. if it isn't TZ102Z2DBA or ... 2CBA, then don't buy it.
only the -KF is missing, this isn't really part of the model number, maybe a date reference i don't know. but still not needed. Sport Utility Sedan, basically it's an outback sedan rather than an outback wagon. CORRECT, but double check the model number on your trans bell housing at the starter. no, if you stick with the 2 listed model numbers, you don't have to worry about gear ratios or anything else, as long as someone didn't change the trans and rear diff. again check the model number on your trans at the starter.
this trans was used in with the 2.5L engine in 98 and early 99. this includes outback, GT and LSi if they made one that year. you could also use the 97 2.5L trans, TZ102Z2CBA. unless the former owner replaced the trans and the rear differential, which is doubtful, you have to use a 2.5L trans. this is designated by the 7TH position '2' in the trans model number. in 99, late, they changed the to the phase II trans and the wiring harness changed so you can't use those or later (they end in ...ZJEBA). 96 trans are a little tricky because there were 2.5 outbacks and 2.2 outbacks, but again i think the 7TH position '2' is key. it has also been posted that the last 2 positions in the trans model number mean nothing. they only indicate which car the 2.5L trans was used in, GT vs. outback. so this means that a TZ102Z2DBA = TZ102Z2DAA etc. but it would be good to confirm this by comparing a SUS trans with a OBW. i don't think you need the TCU if you use the 97 - 99 (early) outback trans. a recent posting had a link to a transmission part supplier and they sold a rebuild kit for legacy/outback trans which works for 90 - 06 legacy a/t. this would suggest that the trans for all these years are very, very similar. it is my opinion, and only my opinion that all of the late 90's legacy/impresa/forester used the same trans. they just made it work differently for different models by changing the final drive ratio and the shift points by changing the TCU. just my opinion. so to answer your question, 97 - 99(early), with model # TZ102Z2CBA or TZ102Z2DBA. that is unless they changed the rear diff. your trans should have the model number on it where the starter is bolted on, driver side near the fire wall, under the air box(?).
perhaps in an empty parking lot with snow and slush... try braking hard , let the ABS do it's thing and then pull on the parking break. just remember to keep the push button depress so you can release it if needed. you should still be able to steer the front of the car (a little) but the rear will probably lock up. this may well create the WORST of both worlds. or do some test to see if pumping will in fact disable the ABS.
i thought of this on another cooling thread, why haven't they gone to a computer controlled valve instead of a t-stat? everything else it computer controlled. obviously the mechanical ones we're using have worked for 100 years, but imagine how much coolant flow you might have if the computer sensed over heating and opened the valve 100%. cars without a t-stat run much cooler than those with, too cool , because there's less restriction in the pipe at the t-stat location. just a thought.
it's pretty easy to remove the hub asembly and almost easier to remove it with the axel still attached to the hub. (when i did it i couldn't find my socket for the axle nut so i just swapped the hub and axle.) i removed and reinstalled the hub/axle on both my 97obw and the donor car in about 4 hours. remember to mark the position of the top strut to hub bolt before removal and you may save the expense of an alignment. the top strut bolt adjusts camber, i think. but just because the boot on the axle is torn doesn't mean you need a new axle. and the way i here it these things, bearings and axles, make noise for a while before they fail. so maybe the rear can wait for warmer weather. but if you are buying a used assembly, why not get the axle with it. it sounds to me like this guy was looking for some problems with your car. but it could be he's just being careful and wanted you to know your future so you didn't come back at him and say "why didn't you do this when you did the hub?"
yes it is a plug in unit and easy to replace, but unless you get an off year trans you won't need to replace it. search car-part.com for 92 legacy trans and see whats available. post a wanted ad here and see if you get lucky. also if you search car-part.com for a 92 legacy trans computer one of the early pages will give you a clue as to it's location, lrft side under the dash i think. but again, you don't need one unless you get an off year trans. http://car-part.com/ or this: http://www.crazedlist.org/
the 90 legacy A/T has 2 speed sensors. VSS#2 (for the speedometer) is on the front right of the trans visible from the passenger side rear of the engine compartment. it's abpout 1 - 1.25 inches in diameter, and threads in the trans housing. there is a cable (stiff black thing) comming off of it which finds it's way to the speedometer. possible problems are broken cable, gummed up cable, frozen cable... etc. or there is the possiblity that it is the speedometer, bad unit , bad connection, bad.... it's electric. (in 95 - 99 the VSS#2 is only a sending unit sending electric info to ther speedo. in 90 the cable relayed mechancial turns to the speedo and the electric work was done there.) there is a second one, VSS#1, on the AWD unit in the rear of the trans, very different. rumor has it that when the front one dies the second one takes over, but i thaink this may be for later models only. this is just foe the AWD unit. you should be able to get one used or certainly new online, and not too expensive. easy to replace, i think. but you need to determine if it's the VSS#2, cable or speedo. try: posting a wanted ad here or http://www.carpart.com and search.
yes, you need to replace the trans. once they start to slip it's time to replace. search for a replacement trans. buying a used trans will be cheaper than a rebuild. labor for removal and replacement will be in the 5 hr. range. when i did it i think it was more like 7 hours including the rear main seal and the 'seperator plate' on the engine. that brings us back to my earlier post, which trans will work. check on the 'for sale' site here, (forum> marketplace> classified,for sale), or http://www.ultimatesubaru.org/forum/forumdisplay.php?f=12 . or post a new thread in the 'wanted' section. now is when you need your trans model number. i would look for a trans close to home. shipping can run 150$ easy, maybe 250$ for coast to coast. so a 500$ trans nearby = a 350/250$ far away. if you have time and space, you might consider looking or waiting for a wrecked 92 legacy. some can be had for 300$ - 600$ and maybe you can sell some other parts to offset your trans expenses. keep at it you're learning more every day. this is not a recommendation but a possibility, and only good for some one with survival skills, willing to be stranded in the dead of winter a long way from home. it maybe possible to drive this car for a while by starting in 1, shifting into 2 and running up the speed to about 40 - 50 or more and then shifitng into D. but again it won't work for long, and it will leave you stranded eventually.
this is a good place to start looking for parts. sort you search by distance so you view the ones within driving distance first. saves shipping. http://car-part.com/ these are the rules on replacement trans. get the same model and year as the one you have, or get the closest model and year you can AND get the TCU as well. (in AWD trans, you have to make sure you match your existing rear diff, but not in FWD.) usually, the changes from one year to the next are generally pretty mild, but in order to avoid buying a worthless lump of steel, if you get the matching TCU you should be ok. check the id tag under the hood on the driver side strut tower for trans model number (at least that's where it is for 95-99) . it should be a TA102Axxxx number. (those 2 'A's indicate FWD, AWD would be 2 'Z's.) the model numbers changed most every year, but that doesn't mean a 93 won't run in a 92. (salvage yards tend to be very careful in this area and they have good interchange software.) the model number is a 10 character number, (TZ102Z2CBA= 97 outback wagon, TZ102ZAAAA= 95 legacy sedan AWD) and in the 95-98 years the last 2 characters mean almost nothing. (BA=wagon, AA=sedan, i think.) in the outbak years, the 7TH character refers to the differential, and the 8TH generally refers to the year or which step in the series. (... TZ102Z2CBA=97 outback, ...TZ102Z2DBA= 98/99 outback, but these 2+1/2 years are completely interchangeable.) the 90 - 94 model numbers were a little different. but if first 8 characters of the trans model number match yours, is a pretty good bet that it will work. there's a good chance it will work if the first 6 characters match since differential isn't an issue (especially if you have the TCU). EDIT: 93/94 legacy FWD= TA102AA3AA; 90/91 legacy FWD= TA102AA1AA; the 92 is probably TA102AA2AA. of course, avoid the turbos. some one else with more 90 - 94 experience may know more. i hope this is more helpful than confusing.
i like the idea of the overheating or lack of proper cooling contributing to the head gasket failure. that would give me hope for the future of my engine. but it begs the question, if this helps eliminate the problem, why hasn't subaru changed the cooling system. even if they didn't admit the fault in the earlier versions, they could have made changes at the phase II point. a larger cooling system / radiator wouln't have been too expensive. as a non-engineer, i'm more inclined to believe the movement theory. this seems like it would be harder to correct. i don't know what it cost or what you would give up with a closed deck design, but it might be worth a shot. question: some of the later 2.5 have turbos, are they closed deck? (like some(?) of the ej22 turbos) do they have the same head gasket failure rate as the open deck design? (assuming they are in the years with the problems).
