03 Legacy
johnceggleston replied to hkerns503's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome basics, auto or manual trans? how many miles? engine, 2.5L (legacy L, brighton) or 3.0L (outback VDC or LL Bean) ? if auto, yes, put the fuse in and see if the trouble goes away. it should be in the corner of the fuse box under the hood, which is located in between the battery and the windshield washer bottle. this is pretty easy to do. any fuse will work. there is usually a spare in the fuse box. the lid has a description of each fuse.
Cause Oil Leak/Check Engine/VDC light after Idley Pulley, Tensioner, Belt replaced?
once they read the code you will have a much better idea of what is going on.
reusing ej series mls head gaskets that haven't been heat cycled
johnceggleston replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbeen there, done that.
Is this radiator ok?
johnceggleston replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif time is an issue, order it on line from advance auto and pick it up in the store the same day. they always have discount working for on line orders. but if you google, advance auto discount coupons, you may find a 33% of coupon. i have done ths lots of times and i have even use some coupons twice. ignore the dates. some of the older ones still work. juust plug in the code and if the price changes you are good to go. it may not be the cheapest, but it may be the soonest. i got something from rockauto this spring and shipping was faster than what was quoted. good luck.
1996 Legacy LS sedan torque bind?... Feels worse
johnceggleston replied to Giovara's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfirst, all 4 tires need to be the same size in circumference, with in 1/4 inch. so they need to be the same brand, size, tread, air pressure, and wear. if they are not you will have binding. second, change the ATF. dirty trans fluid can cause gummed up clutch discs in the transfer clutch and the valve body for the duty c . both of these control the power transfer to the rear wheels. do a drain and fill of the trans fluid, just like changing the oil in the engine. do this 3 times with driving in between each. the duty c is working.
New Guy ... Needs Your Help
on the negative cynical side i thought you were trolling for email addresses. on the positive side, i thought you were interested in how we repair our cars. and maybe, how some one might market /sell repair tools to us. but, you are a student / learning. lots of us have been there. and all in all they were good questions. better than what i would have come up with. if any good comes from this, let us know. best of luck.
done good luck.
Swapping a '00 EJ25 SOHC non-egr into a '03 Legacy
yes, just plug the hole and go. i forgot you were using it else where.
if you use the 03 intake with the EGR on the 01 block and heads you will have to replace that equipment once the 03 is ready to install next year. did you find the write up on the drill and tap of the head?
Failed ECU....93 Leg OBD I ?
johnceggleston replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think the 95 lego is obd2, but the 95 impreza is obd1.
- 26 replies
- OBD I
- CEL flashing
- ECU fail
- Alt issue
Tagged with:
"02" outback ECU question?
johnceggleston replied to schekan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat were the code numbers.? if the part numbers were the say on both parts, it should be ok. were the codes you got the same ones you had on the old computer? are you sure the old one was the original one? why did you think you needed a new computer? some codes require 2 drive cycles before it will throw a code, i think.
- 90 legacy l a/c
turning my leggy l fwd to awd
you also need the TCU to control the transfer clutch. i don't know if adding a AWD TCU will do it. when swapping back the other way in the later 90s, you always end up with a TCU trouble code. the TCU is look for the rear speed sensor. and i have heard it suggested that the harness tells the TCU / ECU if the car is FWD or AWD. not sure. but regardless, in addition to the hardware you need the brain to control it. you may also need the gas tank, not sure if they are different. much easier to put your engine into the AWD car.
Can I spin the crank to fix my cam timing?
johnceggleston replied to scrapheap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnote: when the carnk is in the crrect timing position the crasnk keyway is pointing down, in the 6 oclock position. but you will have to remove the crank pulley to see it. not the sprocket, the pulley . you may be able to ''feel'' the key way with your finger when the pulley is still on, and the bolt out. when the crank is in the correct position, all pistons are at mid stroke, not the top and not the bottom.
replaced water pump, car wont start
johnceggleston replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtime to check the fusable links in the fuse box under the hood.
johnceggleston replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhorn work? battery connected? 2 large connectors on the rear of the engine passenger side? double check. now, put it in PARK, and try again. did you have any SPARKS at any time during the process?
Torque Bind, FWD Fuse, and the Duty Solinoid
go to http://opposedforces.com/parts and look for the TCU in the POST cars of similar years. i forget what they call it. once you get to the list of categories, click the browse button. it will be a little difficult to find, they put in an obscure place. but i do remember it is at the bottom of one of the categories. at least the ECU it. EDIT: don't bother, it does not show any info about the location. it is however called ''AT Control Unit'' and is located at the bottom of the auto trans category. not yours, but looks similar to this.
transmission swap question
hi jack, does this mean the trans defaults to open when the dutc c fails, instead of binding? that seems like a good thing. also good to know where the cut off line is for a compatible 99/00 - 03 auto trans. another good way to tell the difference between phase 1 and phase 2 is the screw on filter on the driver side of the trans. kind of near the LF axle.
Rear Camshaft Seals
johnceggleston replied to Sangerboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the driver side head leaking from the rear seal. i have never heard of this.? if it is not leaking i would leave it alone. if you cannot not find it in link below you will have to ask the dealer parts guy. and the dealer, online or local, is probably going to be the only source for the part anyway. http://opposedforces.com/parts/legacy/us_b11/type_6/engine/camshaft_and_timing_belt/illustration_1/
99 Lego OBW EJ25 knocking-dead, swapping in 95 EJ22
johnceggleston replied to jiggseob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have the donor car charcoal canister you can add it up front. i have done this. or you can jut build a U shaped hose and connect the 2 front metal lines to each other. i have done this. or maybe just plug them. not sure. not sure about this. the pluming to the rear canister is in place and will work perfectly with the 3 exisrting hoses that connect to the intake near the fuel filter .
johnceggleston replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNOT the arrows, NEVER the arrows.
97 Legacy Outback engine Swap
johnceggleston replied to zstamp19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcrank sensor triggers the spark. cam sensor triggers the fuel. check the crank sensor, coil connectors and the the wire feeding the coil.
johnceggleston replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhere did you get the ALT?
- 26 replies
- OBD I
- CEL flashing
- ECU fail
- Alt issue
Tagged with:
Installing 4WD fuse = Car no longer shifts
my guess is that you are not in 1st, but in ''limp'' mode and 3rd gear only. and some how the fuse is ''killing'' TCU. it should not do this but for some reason it is. test drive the car with the fuse in at 40 mph and see what the rpm / tach reads. if you are in 1st it should be screaming. if you are in 3rd, not so much. compare your results to driving with the fuse out and the selector in 3. but as long as the car / trans works fine with the fuse out, leave it out.
swapping front axles
the axles 00 - 04 will work on the 95 - 99 cars, at least until they changed from axle stubs that stick out. i'm not sure when that change took place. most folks just knock off the tone ring for the abs. i have done it with no issues.
