WTF (What the fluid)?
johnceggleston replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen you get the engine installed, i would fill the cooling system with plain water to flush out any other gunk that may be hiding in there. then after you find that all is good, you can drain and fill with 50/50 coolant.
90 legacy overheating.
johnceggleston replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would amend this to read 90 - 95 will fit. every 96 i've seen has a single port exhaust. 96 - 98 will require a different exhaust y-pipe. and the 95 - 96 engines from cars with auto trans will have an EGR on the intake and driver side head. not a big deal, you just do not connect to it since you have no connectors in your car.
Would the tranny out of my 93 Legacy L fit a 97 imp L?
i don't exactly understand the question, but if you are asking will the lego trans bolt into and mate with the impreza engine the answer is absolutely. the bell housings and the torque converters for ej22s and ej18s 90 - 98 are all the same. so are the wiring connectors. you don't see anything different until you get to the ej25s or 1999. your trans guy wasn't a subaru guy was he?
98 outback sport keyless entry
johnceggleston replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's it. all i can say is try again. try holding it for 30 or 60 seconds.
johnceggleston replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand the button you were pushing and holding is a part of the wiring harness for the keyless entry ''black box'' under the dash??
johnceggleston replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the key in the ON position? not just the the first click where the radio comes on but the next click where the AC / heater fan will blow and the headlights are on and all of the dash lights are on. that was my mistake on my first try. did you replace the car battery or the fob battery? does the fob ''light'' blink when you press the button? if it has a light. is the battery in the right way?
Which is the Least Costly?
johnceggleston replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsince you are confident it was a bad product, how about sharing the name so we can avoid that seller. was it ''dewy cheetum and how''?
johnceggleston replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot long i don't believe. the belt would die. i would refill and burp. replace the cap. and start saving money. no gunk in the overflow bottle? have you had any recent work done to the car???
Electrical Help Needed
johnceggleston replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXseems like you have all this info but just in case. http://www.obd-codes.com/p0443
ej18 power steer pump.
my point is simply this: if the steering rack was designed with ''power'' as an integral part of the system, it may not be geared well for non-''power'' driving. but i think the likelihood of that is much less on a mid 80s car. but removing the belt and test driving will answer a lot of questions.
Who here has/had a justy?
johnceggleston replied to jonas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnipper picked one up last year, a 92 i think. i would be driving one around town if i could find one in decent shape and didn't have 3 other cars on my to do list. i hear the auto trans is crap, unless it was well maintained. and i hear they don't really have the long life we are used to in other subarus, but i don't really know. but other than that what's not to like. i don't think i would drive it on the hi-way a lot and compete with 18 wheelers and the like. this of course lessens it's usefulness, but doubling? my mileage around town would be good enough. save energy and hopefully save money. but if it was a third car the cost of owning may off set the savings. i'm also interested in those gas powered ''golf carts'' that can go on roads up to 35 mph. for me, driving to work - 2 miles, getting groceries - 2 miles, dropping the kid a school - 3 miles and visiting friends, < 1 mile, it's a no-brainer. but the justy is probably cheaper to buy.
Anyone tried greasing an alternator bearing 1993 Legacy L 190Kmi
johnceggleston replied to illanrob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you can ID the bearing you can probably pick one up for $6 - $8. but the trick is figuring out which one it is. my best advice, short of swapping in another used ALT is to remove the bearing and take it to a parts store and match it. the r&r of the bearing is the same labor as trying to re-grease it, i would think.
just so i under stand, you have a brat with an ej18 swapped in and you want info on removing the power steering pump. i repeat my earlier post, have you test driven the car without the power steering working???
this is just a thought: cars with power steering when it was the onlt option, are not designed to be driven without it. without the ''power'' they are really hard to drive. the ''gearing is designed for ''power''. cars that were designed with ''power as an option can be driven without the power. what ever the gearing is , it is drivable. case in point, my 90 nissan pick up w/ 2.4L, 4 cyl. engine and 5 speed 2wd trans. it came without power steering. i don't know if ''power'' was / is an option. but i'm pretty sure the 6 cyl 4wd truck did have it, at least as an option, but probably standard. my nissan is very drivable, but the last time i was driving a car when the ''power'' belt failed it was a nightmare. i felt lucky to get to the side of the road safely. i did make it home but it was not pretty. just a thought.
radiator fans stopped working
one comes on when the AC is turned on. try that.
Bar's stop leak, radiators (and a bleeder plug)...
johnceggleston replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou might consider leaving the rad cap or vent plug loose to reduce the pressure on the system and hopefully help the barrs plug the leak. this may cause the water to boil out and adding water daily, if not more often, may be required. good luck getting home.
have you test driven your car with out the ''power'' steering? if not you may change your mind. if you remove the belt you can test drive it around the block. you will also lose the ALT. but for a short test drive you should be ok if your battery is ok.
95 Legacy 2.2l 2WD Transmission problem
johnceggleston replied to Wheelspin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds like a match. less then 3 hrs. to louisville.
johnceggleston replied to Wheelspin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe's in anderson, indiana. where ever that is?
97 Legacy GT misfiring on all 4...
johnceggleston replied to mpudz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell it turns out that i have been reading too many online forums and believing them. it appears that the stock plug for the ej25d is not a $2.00 plug but a $10.00 plug. according to the site below, the stock plug is a ''premium'' class plug. and the $2 plug is a regular class plug. there are also several in between. http://www.ngk.com/results_app.asp?aaia=1305548
johnceggleston replied to mpudz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfrom the 98 owners manual. Spark plugs 2.2 Liter models RC10YC4 (Champion) [Alternate] BKR6E-11 (NGK), K20PR-U11 (NIPPON DENSO) 2.5 Liter models PFR5B-11 (NGK) Spark plug gap 0.039 to 0.043 in. (1.0 to 1.1 mm)
johnceggleston replied to mpudz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif so, my mistake. i just don't remember hearing them referred to that way.
CV Boot Question - Front
johnceggleston replied to idaho2010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnipper, please edit one of these post so there is less confusion and more correct info. thanks
johnceggleston replied to mpudz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi don't think the NGK V coppers are stock spec for this car. if you are going to change out the ones in your car, put in the stock spec NGK plugs. they only cost about $2 each and they work great. the better ones you are running may be fine, but they are not stock. and if they are causing a problem the stock plugs will cure it. keep it simple.
johnceggleston replied to Wheelspin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa good place to look for parts: http://www.car-part.com a pick-n-pull or someone local on craigslist or the like may be a better price, but at car-part you can search the whole country. put in your zip and sort by distance.
