9
the 96 - 99 ej25s tend to have head gasket issues with exhaust leaking into the coolant. the conditioner does nothing for these engines and i don't think subaru ever recommended adding it to them. however, the 00 - 03/04 ej25s had external leaks and subaru would extend the warranty on the head gaskets to 100k miles for some of these years if you added the conditioner. and it is my understanding that subaru requires, strongly suggests, that the conditioner be added to the coolant on ALL engines.
it is safer and less likely to ruin your new trans to swap the matching rear diff. there is a current thread of some one who just did a front diff swap only to swap it back. apparently he was afraid it would self destruct if he hadn't done it right. i'm sure it can be done, but i would never attempt it myself. way too much chance for an expensive mistake. i'd hold out for the correct matching trans if i was you.
gary probably does have one but if he doesn't some one else will. if you click on gary's name to the left (or above) of his last post you should be given the opportunity to send him a Private Message. that will alert him . and or you can post a ''wanted'' ad here: http://www.ultimatesubaru.org/forum/forumdisplay.php?f=37 welcome to the party.
the BEST subaru on the road, IMHO, is the 96 L/LS wagon. it has the non-interference engine, lots of room for hauling stuff, roof rack is a plus, and there are lots of them out there and easy to find for a good price. i prefer an auto trans but either is good. the 96 sedan comes in a close second. my favorite subaru on the road, is the 98? - 99? outback sedan. i love the outback look on a sedan. but.... this is not a candidate for a reliable car unless you swap in a 2.2L engine or buy it before it overheats w/ bad head gaskets and repair it. the 96 - 98? LSI or GT comes in a close second, but they need the ej22 as well. i gave my son my 95 lego sedan when he graduated from high school. it had 160k miles and i had just replaced the trans. (i bought it fir $5500 and drove it for 90k miles. the trans died.) he drove it for 5 years and 49k miles. as long as they hold oil they will not die. i just swapped it out for a 98 outback w/ 142k miles and an ej22. find a decent 90s subaru with a non-interference engine, you'll be glad you did!!
you have driven 80k miles and you paid $3500. that's less than $.05 per mile. if you bought the car new for $20,000 you would have to drive it 400k miles. how many new cars sold today will do that. but, it sounds like you put most of these miles on the car the first year. and that this year your total will be less, maybe less than the national average. a commute of 14 miles per day isn't very much. so there is a chance the car will start to ''age'' in spite of the miles. and rust is real car killer. i would fix the car and start a car fund, $100 a month? (don't use the car fund for repairs.) then when you do need to replace your car, you'll have some seed money. i also like the advice to start looking now. if you find a good car for a good price jump on it. but you never know what you will be getting.
assuming your car is AWD and not FWD, yes you need to get matching tires all around. as a stop gap measure, you could run the larger ones on the left and the smaller ones on the right and not cause any more damage, but long term this too may cause trouble for your front and rear carriers. but i doubt that this is causing your shudder at 55 mph. does it do it at the same rpm / speed in '3' instead of 'D' ?
do you mean the crank pulley came off of the crank shaft? maybe buy it, put the trans in your car and drive it until you find a ''newer'' replacement. then sell yours. the ''new''engine in the FWD car is a pretty easy fix and could be sold for a few $$. plus you'd have a parts car, assuming you have a place to store it. scrap cars are going for $9 - $11 around here. so that would be ~$200 for scrap value after you pulled the engine and trans. so, buy the FWD car for 500. sell the engine for $200. scrap the rest for $200. use the trans. it cost you $100 to put your car back on the road. of course it would be better to buy an AWD car and do this, but it just depends on how big a hurry you are in.
i think an awd fwd can be made into an awd. most of it is just bolting on the rear extension housing. but you also need to add the clutch drum on the trans side of the transfer clutch. i don't really know what that takes. it has been a while since i looked at one. then you have to make sure the wiring harness on/in the trans has the duty c connector. have you looked for a trans here? www.car-part.com sort your search by distance, shipping is expensive. NOTE: some early FWD trans had a 3.7 ratio, i think. so you'll neeed to avoid those or you will be re-working both ends. the trans would have to be almost free to justify all that work, imho.
92 - 94 auto trans have a 3.9 final drive ratio. that may be a little difficult to find since 95 - 99 auto trans have 4.11 for the ej22 and 4.44 for the ej25. but any non-turbo 92 - 94 should work. or you can use one from an earlier or even later car as long as you use the matching rear diff. they all bolt in and work the same. (except for the speedo connection which i hear is an easy conversion.) 90 - 91 non-turbos have a 4.11 final drive. and turbos do not follow these rules, but i'm not sure what they are or aren't. somewhere, there is a link to a page with all the ratios for the early 90s. it is part of http://www.experiencetherave.com i think.
i drove it for a couple of months without reverse. i learned to park very carefully. and a few times reverse would catch when i was testing it, but there was no rhyme or reason to when it would. hot or cold , rarely would it catch. but i found a 97 obw in my price range before i found a wreck in my part of the state. so i upgraded and gave my son the 95 lego.
