AussieIan
Everything posted by AussieIan
CV Boot
AussieIan replied to AussieIan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks Guys, the cable tie solution seems to be the go. -
hesitation
AussieIan replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Some do have some very strong views about cleaning TB's including Josh who really does know his stuff. Anyway I went ahead cleaned mine anyway, I bought new gaskets for the TB to manifold in case I broke the old one. I removed it, there are some pesky water hoses and other bits and cleaned with with brake cleaner because it does not leave a residue and also cleaned the IAC valve with brake cleaner according to Josh's recommendations. The cars driveability certainly improved. Whether it was due to the TB or IAC is debatable. I must say the TB was not nearly as badly gunked as I was used to seeing on my V8 Commodore. I also reset the TPS sensor after I reassembled everything and it was quite a bit out. So whether you clean it or not is your call. I'm inclined to think it they do not cleaning regularly on Subes. -
hesitation
Fair enough, and at least you know its in the tank. Ive heard many stories of operators forgetting to turn pumps on when blending gasoline etc. Have you noticed a payback for your investment in the aditive? I've only done 600km since changing to premium, so far it appears the gas mileage has improved a little but its too early to tell. Cheers -
hesitation
I think it is probably cheaper just to use premium with the additives already in the fuel than add it, where is the cost benefit? The fuel quality has plummetted here as well, the addition of ethanol is being blamed rightly or wrongly. -
hesitation
According to my mechanic its not just the octane. He has found that engines running premium fuel are cleaner, from the fuel injectors, heads even the exhaust system and this is the real benefit. I'm trying it my Sube, so far insufficient k's to see if any real improvement in gas mileage, but the hesitation has gone. BTW someone advertises a add on which smooths the signal from the knock sensor and cures a lot of hesitation problems. Might be worth a look if the problem persists. Cheers -
hesitation
Did you refuel during the period in question. With sky rocketing fuel prices here in Australia we also seem to have plummeting fuel quality, I was having similiar problems to you until on the advice of my repair shop I went off the discount regular fuel and went to premium unleaded. The difference was immediate. Its worth a tank to eliminate the possibility! -
Some time ago I found a Subaru Tech bulletin on a modification to stop the wind whistle from the front windows, it involved putting spacers between the door metal and the triangular pieces that support the rear view mirrors. I saved this paper and other related papers to my hard drive but unfortunately lost the lot. Any one any ideas. I really need to fix that whistle!
Totally agree split boots are useless. If your not getting any clicking on full lock turns just replace the boots. Subes are very easy to do thanks to some thoughful engineering. I did mine in about 3 hours both sides. The boots I purchased had a pack of grease with the boot, wear plastic gloves when your handling the grease it really gets into the pores of your skin.
When the motor is heating up gases and other things are being forced via the leak into the cooling system because of the difference in pressure. When you turn the motor off things cool down and coolant is sucked in via the leak and decreases your coolant volume, the coolant that has been polluted by the first step. You probably have a faulty head gasket(s). Either way urgent attention is needed. Your oil probably looks terrible too!
The grease in CV joints is usually a MoS2 based grease. Its usually not all that waterproof because if a boot gets torn the grease will be washed out on wet roads and lead to rapid failure of the joint. In Australia the replacement boot is supplied with a packet of the grease. If its still clicking and the boot is intact and the joint is packed with grease I suspect your CV is not worn worn out and the clicking may be coming form elsewhere. Good Luck
Subes like thin oil and they like clean oil. If not changed regularly you end up with very noisy tappets. I followed the Haynes manual lub recommendations on tranny oil and have had no problems. Josh did have a complete owners handbook for a Legacy on his website http://www.surrealmirage.com/subaru if you have not got a handbook. You can't go wrong by following that. Cheers Ian
Hmmm I assumed that when they replaced the shocks that they would check the mount and bearing plate, that sure sounds like where it is coming from. I removed the jack, spare etc from the boot to eliminate those sources. Also gave everything a good wiggle with no joy when the car was up on stands. Thanks for the replies. Ian
