JimmyJam
About JimmyJam
- Birthday 08/17/1975
Location
Philadelphia
Occupation
Self Employed
Vehicles
1995 Subaru Legacy L
JimmyJam's Achievements
Advanced Member (3/11)
10
1995 Legacy Wagon 2.2 355,000 AWD Automatic The noise is coming from the front driver side. It starts around 50mph. It does not go away while turning. It is steady sound but when I hit a dip in the road it gets louder. Its independent of acceleration and lacks vibration. It had all the classic signs of wheel bearing noise but I repaired both sides and it is still there. The tires are newer with only 2k on them. Alignment was done around the same time. I will rotate the tires to see if it changes. Question is will a cv joint make a steady noise? (no clicking while turning) My fear is the differential side bearing is bad. What sound does that make when it goes bad? Differential fluid was a little low. Not a whining sound.
91Loyale said "With vibration in the steering, that's almost always an issue with a wheel or tire rather than the steering linkages. Hitting a bad pothole could dent a rim or make a tire lumpy. Try rotating the wheels front to back and see if the problem goes away." Good job 91Loyale! I did move the tires front to back and it did go away. The tires in the back were in very good shape. The front right tire was messed up from trying to get out of a snowed in parking spot(4wd not working right now). Wheel spin, hitting asphalt after a few tries made it bald. I still have a funny feeling the rack is a loose, but the good tires do not cause it to move around. Thanks.
Yes I did post this in another thread. I have two problems I am trying to figure out. I have multiple problems but this one I can't figure out. My steering wheel only locks 90degrees off center now. The wheels and steering wheel are still aligned straight. So, if I hold the steering wheel straight the wheels are straight, but when I turn off the ignition and take the key out, the steering wheel does not lock unless I rotate it 90 degrees. It did not do this before. What causes this? Now on to the other problems. I think my steering rack is thrashed. When I am going under 10 miles an hour, there is a lot of play and some shaking in the steering. I checked tie rods, ball joints, cv, brakes, wheel bearing, etc. They all feel firm with no play. If I go under the car and somebody moves the steering wheel left to right quickly only a few inches, there is a metal on metal knock or ping coming from the steering rack. Steering rack u-joints feel tight. When I do a full lock turn, there is a noticeable groan/noise and 'bad' feeling in the steering. Power steering fluid level is fine. I also did hit a pretty bad pothole the other day. I did find a cheap used steering rack and I am willing to replace it, but I am not sure what to do about the steering wheel lock problem and if they are related. 1995 Legacy wagon 285k Auto
Ok, I am sure it is fixed now. The gremlin came back a few days after I installed the new pump. (Hard start after running it all day) Well, I finally got a check engine light and had it checked at Autozone. Code was for faulty crank position sensor. Got one there for $25 and looking good so far. What are the chances...a failing fuel pump and bad crank sensor at the same time.
It ends up it was a fuel pump with a dead spot. That is why I was getting intermittent hard starts. I check every sensor and they all were fine. I pulled the pump and applied power to the red and black. It ran fine. Took it back to the car and hooked it to the harness. Did not run. Took it back inside and it did not run. Smacked it with a wrench while applying power, STARTING RUNNING. Back to the car, harnessed, smack, RUN. I think you get the point. Replaced it with a new pump and screen filter($112) and everything runs well. Yeah! Good job NorthWet, you called it. Don't worry guys, I know you all thought of it too. hehe Maybe relieving the fuel pressure helped the ailing pump start better??? I am glad to know all my other sensors are fine. Well, I did find a stuck PCV valve. $5
Lately, I have had problems trying to start my car. Very intermittent. Maybe 1 out every 50-100 starts. I would have to crank it for a while(20secs?) before it starts. Yesterday, I unplugged my fuel pump, cranked the engine to relieve fuel pressure, hooked the fuel pump back up and it started right up! Later in the day, it was hard to start so, I did the same thing. Get this, the car started without the pump hooked up! It happened when I was trying to relieve the pressure. Quickly, I hooked it back up and it continued to run. Otherwise the car runs great. The fuel pump sounds good. It starts right up the other 99 times. ??What would be causing this?? I am stumped. Is it too much fuel/pressure? Flooded? Injectors? Regulator? I haven't kept track but possibly after it rains/High humidity?? I have also had success revving the engine when I turn it off to ensure a good start. 95-Subaru Legacy Wagon-2.2L Auto 230,000+miles New fuel filter. New Air Filter. Thanks Guys.
