sailhard
Location
boston
sailhard's Achievements
Advanced Member (3/11)
10
Well, it started intermittently ( every few days) blowing the inline fuse again. 2 boxes of fuses later I switched to a 30A slow blow 3 days ago...It never blew, but once the windows stoped working and there were 2 relay clicks every few seconds for a few minutes, and then the clicking stopped and eveything worked again. Today I got home and the the windows/locks had stopped working again, I figured the fuse had blown but it had not. BUT with the ignition off there was a sight buzz from under the left side of the dash when I hit the power lock switch. I tracke the buzz down to a relay(7) on the far left side of the das, above the fusebox door. I assume this is the relay/circuit breaker that cougar described...I'm going to try and replace it...anybody know the part number??? Or better yet have a spare? I just reread cougars post...it looks like it's the window relay that was buzzing..where the heck is the power window breaker?
Sorry it took so long, but I wanted to post the results. What I ended up doing was removing the washer tank and then removed the screws holding the Fuse box to the fender then I was able to remove all the molex connectors from the bottom of the fbox and sort of unkinked and straightened up all the wires to the connectors...I couldn't really tell exactly which connector went to sb-6....but when I put it all back together and installed my new fuse it worked and has been working fine for weeks. I eliminated the rip-off 30 amp slow blow, by replacing it with an in line fuse holder and 2 crimped on tab connectors. It fit under the FB cover nicely.
Thanks guys! It's snowing hard right now but I'll check the wires under the fuse block to firewall and in the door by the hinge soon. I plan make an in-line fuse holder with crimped connectors to test with. Thanks for the wiring description. Good thing, as I looked in my haynes manual wiring diagram and there doesn't seem to be any sbf-6 on it....
It's a square pink 30 amp slow-blow fuse in the hood fuse box...never saw one before...$5 what a scam....what's wrong with bus fuses and breakers??? Where would I find a 30 amp 12v dc breaker to troubleshoot with? It's very cold and get's dark early, so I pretty much have to frig with it in the lot at work. I'll check out the manual tonight...I already know that one slow blow at least powers the windows and door locks...so right thereit could be 1 of 4 window motors or solenoids that lock the doors. I'm temped to put a 40 amp slow blow in there or a jumper and see what's cookin'...
Finally having a problem with the Forester after 88k miles... I went thru the toll booth this am, lowered my power window, raised it, then 5 minutes later when I was trying to use my security card at the gate at work, no power windows, then I noticed no power locks as well. Found blown slow blow fuse...SBF-6 and got replacement for $5. ( WTF? ) Locks and all windows worked in autozone lot, went back to work and it's blown again. DOH!!!!! Any subie owners have this problem?
When the oldest one is 4 or so, they can use a "booster" seat that takes up less room, the baby can be in the "bucket holder" and the middle one in a "baby seat". Then hopefully in a few years you'll just have 1 or 2 booster seats and a baby seat. I think 3 full size baby seats would fit, but they would be hitting the doors for sure. It can be done in an legacy ( at least in a '96 L), but they are within easy reach to hit/grab each other each other and commence screaming.
What I meant by "4wd mode" is when there is more than the "normal" 10% of torque automatically being supplied to the rear wheels, from actual detected slip or "missmatched" tires. Yes I was only refering to automatic transmissions.i So whenever you get a flat that is not repairable, and have "used" tires, you should just bite the bullet and replace all 4 tires. That sucks balls!!!! I still think that it you had to drive a newer automatic subie in slipperry conditions ALL of the time you would kill the transfer case....which also sucks. There was no warning of any of this in the manual either.
I recently had to take a $2500 bath on a TB'ed 96 legacy l 2.2 that I HAD to get out of my yard. I sold it cheap to a friend, with the recomendation he get it the TB fixed asap. ( I'm sure he won't ) When I got the '96 it had 3 50% worn tires and 1 brand new one. She had 80K miles and no TB. It developed the TB at around 100K while driving back and forth from snowy ski resorts ( solid 16 flash at temp light ). I then learned all about TB...needing exactly the same size tires, and if you get a flat, put in the fwd fuse, the transfer case cover flaw.. blah blah blah etc. My question is: if having one tire a bit bigger did in my tranfer case components, does that mean if you used your subaru in the snow or mud ALL the time that it would be doomed to fail as well? ( since being in 4wd mode is "bad" for it). I also wonder if the 92-96 awd trannies are more likely to get TB than newer versions.
I did it in a 74 ford country squire wagon with a 400 4 bbl. I was going about 50 on a side road at about 1 am in the winter fog, packed with partying friends, we went through an intersection that was well lit, then in the shadow ahead I suddenly saw 2 cars all helter skelter in both lanes with no lights on whatsoever that had been in an accident, with like 6 dazed kids standing around in the street. I stomped on the brakes, realized it was much too late, so I put it in neutral, GUNNED the motor up and popped it into reverse. It started spinning the tires backwards and I lost momentum just in time to hit one of the cars open door and pop it shut. Then the tires really bit and I went flying backwards about 40 mph back to the intersection and stopped. No one was hurt and I beat that car for another 6 months, although eventually the motor/tranny mount(s) broke and the motor slumped down about 4 inches on one side, and the head gaskets went so when I shut the motor off, it would blow steam out the block. Oh to be young again....
