robertwheeler
robertwheeler's Achievements
USMB is life!
USMB is life! (4/11)
10
  1. I like felpro too.... I think im going to have to do this and may be twice.... do you have a blowup/procedure to remove the intake for this engine? Looks like I remove the plenem (spelling?) and under it is the intake and all the injectors....it looks like you can pretty much pop out the center... w/o removing the injectors... What ya think? Robert
  2. Turns out its a leaking intake that GM was to have fixxed sometime ago. This is really a job I dont want to do.... But just in case... Does anyone have the low down on removing the intake off a chevy 3100 engine for this 1996 lumina? I doubt I can screw it up much more then GM has already. Thanks Robert
  3. My Dad asked me to bleed the brakes again today. I think there was just a hint of air in the ABS Modual. None that I could see at the slaves. But this made both my folks happy.... My Dad is my Mom's world.... Meanwhile.... this car seems to need a fan... got maybe 2 coolant leaks and has a bad sensor (coolent level). Can you say Freeze out plug? Ick. Robert
  4. All Done and it really diddnt take that long. The link was a must... w/o the computer dongle to tell the abs modual to use the back brakes it could have taken a while to figure out that all you had to do was drive back and forth a bit. I would have figured it out but the link was a big help. So My Dad is very happy.... And I learned a bit about ABS... early GM abs anyway. Thanks for the help! Robert
  5. Got the master changed but dont really understand the ABS stuff. I pretty much took it apart and put back together like it said. Started to bleed it and then the leak made itself known.... about the center of the car to the passenger side rear wheel. I examined the line myself.... and it fell apart in my hand. Told my Dad what to get and I should finish it on sunday, Should be an easy 90Degree bend to the slave.... Gave this the part of the old line to match it up. Robert
  6. I dont like haynes.... never seems to go into detail and in this case... maybe even incorrect. Robert
  7. Good Page. Also reminds me that we tried to bleed the master/abs mod... Only one would bleed and the other had no pressure. But I think we are back to the master again. There are 2 bleeders on the ABS Mod. Robert
  8. To Tell you the truth I was so shocked at the drivers front not having any pressure.... I just figured the master has a blowed O-ring... The Haynes book says dont take it apart.... but it looks fairly simply... 2 connections and I think.. 2 bolts to the master.... the master itself has 2 bolts to the vac assist. I just dont want to take it apart and have to tow it to get it finished... Sigh Robert
  9. Im inclined to agree.... but my real problem is that the ABS mod is bolted to the master and im not sure its safe to remove it. All the brake lines go into the ABS Mod.... Also... no brake pressure on the driver side.... never seen this one before... but It could be either part. thanks Robert
  10. I dont know anything about ABS.... but the master on my Dad's lumina seems to have suddenly gone empty. Filled it up and pushed and pushed and repushed but we cant find any leaks. I tried to bleed it.... the front passenger side was on... no air but at least I had fluid. The other side diddnt even make any pressure ... no air no fluid nothing. My First guess was the master but then this thing has a ABS modulator connected to the master and at this point I told Dad im just not qualified to diagnose this one. Haynes says not to seperate the abs mod from the master... but I dont know... Any Ideas? Thus far his mech isnt returning our calls and its not really safe to drive... but that old man has a major stubborn streak. Will the Abs mod go right back on the new master? The book says something about special tools... but the new master dosent look that complicated. Thanks Robert
  11. Hi If you read anything in the main off topic area you may have seen that Im trying to hold my honda together until I get my check and can go shopping for a slightly Used subaru. I have been been keeping an eye out on a few noises. There was one I couldnt quite figure out. Mostly my fault because I diddnt get it sooner... But the Noise that I thought might have been a wheel bearing on the way out turned out to be the outter tie rod end on the driver side. 33$ and this car is taking my money and my flesh a bit at a time. At any rate... near as I can tell there wasnt any grease on either of the outer tie rod ends... 8 oil chances and no grease. Damm! The dammage was unreal. At first glance the rod seemed a bit loose but ok. I knew it was shot because it failed under load. I grasped the base of the shaft and pushed it over and under a bit of pressure it moved nearly 1/8 of an inch. No wonder the car was getting so hard to steer. But this turned out to be one of the best 10 min repairs I have ever done Robert
  12. Hey , Ya had the place remodeled The Honda is still here but its becoming like my GF (a bit high maint). The Muffler fell off a while ago.... and Im thinking about tires and brakes. I think I may have a bad injector. In spite of a full tune and a new coil and good gas and gum out... It still spits sometimes... but never when the engine is still cold. The car is no good on unplowed streets! , Even my old subie was better. Hope you are all well Robert
  13. After all this time I had to come visit. I still miss my subie though. Robert
  14. The people here are so nice.... but the people at the honda forum were so rude and jumped me.... when I reacted in part they banned me. http://www.honda-tech.com/zerothread?id=2071930&page=1 Im ddg2sailor over there..... tell me , Am I real? Robert
  15. Thanks for the kind reply's. My Honda is ok... its just not a subaru Robert
