Quidam
Everything posted by Quidam
  1. Hi Loyale 2.7, Below is an EA-82 28/32 on a JDM Justy intake. It's bolt on. Pretty close in horsepower too. Doug
  2. Hi XOOMER, It's not lost on me that a new disc and TO bearing can be installed and the clutch will be fine. I've done that. What occured to me this afternoon was, the mileage of the vehicle in question, how much slippage, if any has occured, and exactly why the clutch is being replaced. I know none of that. I've went through clutch discs on a street small block Chevy before in 3K miles. Factory 11" discs. Of course, I was slightly younger than you at the time:) So I know what you're saying in that regard. Doug
  3. "Sounds like a crank thrust issue." Without knowing anything more, it sure does. Hard to tell, long distance. Doug
  4. Hi XOOMER, From the notes on my B/A clutch kit: Disc-Japan Mfg. NKK Presure plate-England. Not sure of the mfg. Release bearing-USA. Mfg. SKF Piolet bearing-Japan. Mfg. NACHI I assure you it isn't junk. No matter what clutch is put in the car, it's bad advice to not have the flywheel machined. If it comes down to it, possibly void the warranty. I'm talking about for a dependable daily driver, and if you don't want to mabie end up doing the job twice, or end up living with clutch chatter or things like that. I got that clutch at RA, close-out for a 4WD EA-82 for a little over $100.00 delivered. Doug
  5. Hi, I don't think you'll be disapointed in the BECK/ARNEY clutch. I've used a lot of their parts and have one of their clutches. It would be hard to beat that deal anywhere. Doug
  6. Hi, Another option. Rock Auto. BECK/ARNLEY Part # 0619205 Clutch Set, 200mm Diameter;7-7/8" Diameter;21 Splines;1 Per Car 200mm Diameter;1 Per Car [Wholesaler Closeout -- 30 Day Warranty (Only 19 Remaining)] $54.79$0.00$54.79
  7. Hi, Welcome to the board. Yes, non interference. Consequently, no bent valves if it happens. Doug
  8. Hi, What's the mileage on this car? Wagon, Sedan? Transmission? Your car has a water and oil cooled turbo. One mod that's very effective is to intercool it. A car this age typically needs "all" the rubber hoses replaced under hood. Cooling, vacume, fuel, and so forth. If it hasn't been done. Post those pics, and don't boost it to the moon. Those rings have how many miles on them? Doug Edit: One thought. Do a compression and or leak down test on it. If it's not totally up to specs, any attempts to produce more power are worthless.
  9. One easy thing to do: Put a vacume gage on it and see what happens. Doug
  10. Hi, Yes, but I don't have my hands one it:). Look, logical place to look for the solution is the last place that was worked on. The head gasket job. I asked some questions about that... The timing. As it stands you were running 23 degrees and now 18...something like that. The Map in the computer controlls the timing advance. Not a vacume canister, weights, springs and such. Theoretically, you have 5 degrees too much on throttle tip in. You can see just how much dynamic timing the computer is giving it with a "Advance Timing Light". Look it up, or take it to someone who has one. Then compare it to what the factory specs are. Or just put higher octane fuel in it. In the end, if that's what it wants, give it to it. hth Doug
  11. Hi, Was just wondering if the injecter flows as it should. IDK. Too many variables. If everything checks out, just run higher octane fuel. Doug
  12. So who wants to machine some adaptor plates up? Kaz get a royalty:)
  13. Yes, but...Have you double checked just the normal timing belt install? OTOH, one cam advanced? I'd be looking at the injector pretty close. Doug
  14. I'd say yes. I can't see there being "that" much difference, if any in the spring rates. A big plus would be if the springs you use are lower mileage/newer. That will affect the spring rates. If they have 300 K on them, they're prolly toast anyway. Doug
  15. Hi, How many miles are on this thing? Doug
  16. I had 88 GL FWD front springs in my hand yesterday. I had 88 GL 4WD front springs in my hand yesterday. Only visual difference was the FWD springs had a taper on the top coil. Doug
  17. What I did: Bought a tow rig and trailer.
  18. [quote name=b16a90teg;802906 Well I guess i will be looking for a new EA82 for now. With all the research i did I figured Freeze plugs would be easier then having to take off the heads' date=' etc..[/quote] If you pop the rocker covers off, use a mirror and light, you can visually inspect the freeze plugs in the heads. If they're out, prolly in the oil pan. Last person I know this happened to, had a cracked block as well. Doug
  19. Hi, Did they mill the head? It would raise compression a bit. They replaced the passenger side head gasket only? Wondering, Doug Edit: " When I first get on it, it will ping like it's burning off the built up carbon, then it's smooth." Hi Frank. "Any" ping is very bad. Beats on even the rod bearings and such. Doug
  20. I quote you from your other post: "It had a major oil leak on the right head gasket, so I had it changed along with timing..." Did you see, or did you get a report on the extent of carbon deposits on the piston, head, and valves? Low mileage engine with this symptom, I might put Sunoco 94 in it, and give it an "Itallian tune-up". Doug Edit: I'd also make sure the plug wires were fresh and quality. Cap and rotor too.
  21. Hi, Good to hear it's comming along. Your question back a ways: fill the rad on an incline with the cap off to purge air. I let it off the ramps then put the cap on. Hope you get the heater sorted out. The belts...probably too loose. If they squeek with proper tension, they're too old. hth, Doug
  22. http://www.thepartsbin.com/basket.php?add_item_id=1945369 Subaru OEM is about one seventy one at Rock Auto. FYI ebay: http://cgi.ebay.com/ebaymotors/NEW-SUBARU-LOYALE-RX-XT-XT6-GL-10-FUEL-PUMP_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQitemZ200124415274QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Ford pump. You mean like this one? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400033263047&sspagename=STRK%3AMEWAX%3AIT&viewitem=
  23. The first rad is plastic tank, copper/brass core, one row. The $32.00 plus ship Koyo probably is plastic tank, aluminum core. Still, I can combine shipping for other parts, and get it at Rock Auto about five bucks cheaper than that, delivered. The third, they want little more than a hundred, delivered. Or make offer. Probably make someone a good rad at a good price point. hth, Doug
  24. FYI for peeps who don't know. The botttom rad is for EA-82 GL series. The top one is for Loyale. Different bottom hose. I've looked at a lot of radiators on-line lately. Talk about choices:) Silla makes a two row aluminum for less than two hundred. Some tanks plastic with aluminum core. Some plastic with copper/brass core. Pay your money and take your choice. hth, Doug P.S. I've bought OEM Subaru hoses, they're made out of EPDM. I've bought Gates hoses, they are not. I've bought Dayco hoses, and they are. I'll use up what I have and either buy OEM or Dayco for my cars. Having all in my hands at the same time, I don't want any more Gates. YMMV
