biscuitb32
Contact Methods
Website URL
http://
Location
washington
biscuitb32's Achievements
Member (2/11)
10
Driving today my tranny make a loud bang, felt it from under the car. then rmps raised to 4,000 still driving. Ultimately lost reverse, and now care just reves no go. lol. Sometimes it goes back in gear but slips under load and back to no go. Time for new or rebuit trans I think . Anyways anyhelp or just concur with what I'm already afraid of
Yes I am a stupid stupid person. What it was was a hose leaking going from the fuel pump. It had a small split in it. So when under higher pressure ie. tank being full it leaked bad when gas was low it was hardly noticable except also in warmer weather. Thanks for the help and I'm glad I didn't have to pull the tank Tim
Well I'm no professional, but I changed thermostats yesterday, but it seems the car will still get hot after a bit and the heater is working and not working. But when after awhile it blows steam and water from the passenger bottom side of the radiator. Is this a defective radiator or somthing worse. Help please. Thanks, tim
Okay I posted a little while back about a leaking gas tank in a 90 sub legacy. No lines were leaking but I noticed seapage from the top corner of the tank close to the passengers side tire. Is there any way just to seal the top seam with anything. This must only happen when the tank is full because its not leaking now. Thanks Tim
Help please, I just recently filled up my tank and for the first time I've notice a fuel smell when in the garage. After researching a bit I have found gas leaking from the tank on the rear passenger side. Does this indicate a bad fuel tank? I need to know how to if I need to drop the tank and replace. Thanks in advance for any help. Tim
Hi, I have a 90 Subaur Legacy 2.2 non-turbo and it just recently started leaking at first a drip of water on the passenger side floorboard not the whole floor mat is wet. Is this the heater core? I was running the ac quite a bit recently as its been 100 the last few days. Thanks in advance for any help. Biscuit
Hello, My 90 Sub Legacy Sedan was in a minor but major accident. I have all the replacement parts, two fenders and replacement bumber absorber and bumper cover. It was hit in the drivers side front end. Some people say that it can be pulled back out with the new fender to reference. My question is that the radiator support and the support that the hood lock is on is welded. If pulling dosen't work is there a way to replace that welded things or am I looking at a lot of work ect. I have all replacements which I suppose would mean unwelding from the other car. any advice would be appreciated. Thanks, Tim
I need some help deciding which replacement struts to use on my 90 legacy AWD LS. The ones I have on now are leaking bad and I get a little tire rub in the back on some bumps LOL. I have read a lot about KYB. But I was looking for adjustables but I don't think they make them for this year. If anyone has sugestions I'd be really thankful.
