capn_r
Everything posted by capn_r
Digi-Dash Tachometer with EJ swap (93 Imp EJ18/into 87 GL-10)
capn_r replied to Gloyale's topic in Subaru Retrofitting
http://www.ultimatesubaru.org/forum/topic/101240-were-is-the-tach-wire-digi-dash-ej-swap/?hl=presslab&do=findComment&comment=1074404 -
EA71 fat case with FWD Impreza transmission
capn_r replied to 1000 Pistes's topic in Historic Subaru Forum: 50's thru 70's
If I'm not mistaken the EJ transmission case and an adapter isn't the solution here. There are two reasons for the adapter plate on an EJ engine to EA transmission conversion. First there is the difference in the top fasteners and the locating dowels and second the EA transmission main drive gear (input shaft) sticks out 12 or 13 mm (1/2 inch +/-) further from the front face of the transmission than it does on and EJ transmission case. I'm not familiar with the fat case as to whether it is the same as the EA81 /82 series engine rear pattern but even if it is if the adapter between the engine and EJ transmission will have the main drive gear not reaching where it would need to be. The distance of the stickout would be about an inch shorter than it should be. ymmv -
The elusive hunt for a new EA71 water pump!
capn_r replied to Scooner's topic in Historic Subaru Forum: 50's thru 70's
Rockauto says they have one available https://www.rockauto.com/catalog/moreinfo.php?pk=948931 -
SPFI factory training manual and other stuff
capn_r replied to Crazyeights's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Any updates on this? I would be willing to contribute some funds to the project if it would help. -
Hey Skylar, I found this site that has Snowman's spfi guide that may help clear some stuff up for you. I believe it was about converting EA82 carbed engines but the electrical should apply. http://www.docstoc.com/docs/84143886/Conversion-Manual
Free doors for Loyale or GL DL in Tacoma Seattle area
capn_r replied to mikelp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How quick do you need to have them gone? It may be a couple of weeks before I would be in your neighborhood. -
My guess would be that your negitive cable is disconnected and your grounding through the clutch cable during cranking.
It's good to see that butters hasn't broke in half yet!
List of rims that can be used on older Subarus...
capn_r replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Option 11. Buy these. http://www.ultimatesubaru.org/forum/topic/150474-15-4x140-steel-wheels-aa-customs/ -
I'm not seeing anything. I do now, thanks!
I believe you mean O3 Generators Gary.
I hope you can make this happen, I'd like to add what you have to my library. -
Found a local with a few cars...
capn_r replied to spicypeanut's topic in Historic Subaru Forum: 50's thru 70's
"Good luck! Sound like the good old local hoarding crazy guy. Every neighborhood has one." I resemble that. -
PM sent
