capn_r
Everything posted by capn_r
On the low side (larger) line I have used one from an early Impreza. It fit the evaporator end ( most EJ's are bigger) I did require using the matching Impreza compressor and mount bracket.
Aternator and regulator question
capn_r replied to thekauz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Early (80,81 ish) had external regulators iirc. Later models were internal. -
http://www.indysworld.com/80s/general/wheels/wheels.html
The links are for EA81's. Different issue.
And a different spline size and number.
Any of you guys in Washington State?
capn_r replied to TallonX's topic in Meet n' Greet. Your USMB Welcome Center
What is a "populous XD"? -
quote "And ARP still has not contacted me back with a master list of all of their head studs with size/pitch/length, they love making it difficult to cross reference everything." If / when the do get back to you could you post that information (or provide a link, whatever would work)? I'd like to have that information myself. Thanks
4x140 to 5x100 bolt pattern adapters
capn_r replied to matts87glsedan's topic in Products for your Subaru
It's explained and shown in the first post -
retrofitting a dual range for center diff lock possible?
capn_r replied to marcusgl10z28's topic in Subaru Retrofitting
IIRC the EA turbo manual transmissions that have the 3.7 ratio final have a .87 overdrive in 5th and the non-turbo 3.9 units have a .78 overdrive. The 3.9 with the higher (lower numerically) od ratio is actually higher geared. I don't know if that answered any of your question but I thought I would let you know. -
http://www.indysworld.com/80s/general/USRM/mick-usrm/lsd-swap/lsdswap.html
92 Loyale transmission interchange
capn_r replied to loyaleowner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good call northwet, I spaced on the ratio issue. 3.7 on the turbo, 3.9 non-turbo -
Your Loyale will have 23 spline inner axle cups and the turbo model will have 25 splines. Other than that they should be pretty much the same, maybe some slight electrical differences on switches -
1988 DL 4wd Problem with Rear Wheel Bearing
capn_r replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've pulled the axle with the outer stub attached (like ruparts said) and I ground the points on a large ball joint separator tool (pickle fork) a little thinner and more pointed and drove the tool in the split where the cv axle female end and the shoulder on the outer stub join and got them to separate. Then polish up the stub, anti-seize and reassemble. Or just leave the two attached and put it back in after you replace the bearing. -
EJ22 powered Rx7 ----> now working on EG33
capn_r replied to mellow65's topic in Non Soob Cars and Bikes Discussion
What clutch release (throw out) bearing did you end up using? I seem to recall there was a little issue with that. Thanks -
The mystery of the green switch.....
capn_r replied to that one kid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm guessing it's for the hydrosilator, they were sometimes bundled with the chrome muffler bearing / synthetic blinker fluid option. -
It appears to part of a girt used in steel building construction.
Does it have more than the one cartridge that's in it? Does it list what that cartridge is and if so does it apply to your vehicle? Check out this link http://www.ebay.com/itm/231118116755 it sells with 22 different cartridges and list what their applications are.
- 4 replies
- subaru
- subaru select monitor
(and 1 more)
Tagged with:
RetroRoo now selling Weber Carb Kits on Ebay Store
capn_r replied to ShawnW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your application information for your EA82 listing shows EA81 stuff. -
Can you open your doors yet?
Maybe consider a Samurai transfer case. Stock is iirc 2.28 low range and 1.4 reduction in high range and they have good aftermarket support. Any of the lower geared after market gear sets are also proportionally lower in high range as well.
I believe the 5-speeds were fwd
So you have existing holes with heli-coils? I would consider drilling bolts for safety wire. (Or drilling studs and using castle nuts. Tighten 'em up and wire them to each other around the pipe). http://en.wikipedia.org/wiki/Safety_wire
