capn_r
Everything posted by capn_r
Scott may see your question and reply with pitch and length. If you do source bolts you will want to make sure they don't protrude past flush on the plate so they won't try to act like a jack bolt against the transaxle or engine case. A little bolt end trimming and a flat washer or two should suffice.
Yes, get some dowels. The adapter plate has both the ea and ej dowel locations drilled and they ensure alignment. On your bolts,find out what thread pitch they are (could be sae or uss treads although they are probably metric) and measure the length you need for sufficient engagement and you should be good. IIRC you will need to drill the threads out of the engine case in one position for the bolt to pass through.
I've done a lot of R-12 to R-134a retrofits and pretty much exclusively run ester oil. Castrol makes what they call "retro ester" that I'm not aware of any failures resulting from its use but I also get ester oil from the local napa. From my experience if you use pag be sure and wear protective gloves and eyeware, I have scars from getting some pag oil on my hands that Kenworth used in the mid 90's, it's nasty stuff.
Why is it "improper" to use the EJ compressor?
GD I think you are mistaken on the early DOHC and Phase II piston / compression thing. The Phase II pistons don't come out of the deck as you stated but they have a smaller dish volume in them than the early engines so you unless I'm mistaken (entirely possible) you actually have more compression with the Phase II shortblock / pistons. If I remember correctly the early dish volume is 14cc's and the Phase II 6cc's.
Sorry to hear that buddy, let me know if there is anything I can do from this end. Abe
Thanks Gary we will see what happens. We are trying a long distance thing, Dann is a couple of hundred miles north of me and I don't have any FSM's for his generation vehicle to do trouble shooting procedures from. It sounds like he doesn't have power to the coil, does that help sort out what he might be dealing with? Are the OBD II coils the way I remember the earlier one's where the center terminal on the connector to the coil should have battery voltage when the key is on? Thanks for your responses. Abe
http://www.ultimatesubaru.org/forum/showthread.php?t=63647
Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!
capn_r replied to Ratty2Austin's topic in Members Rides
Yes, I believe any of the EA82 series vehicles born with GD's favorite engine EA82T, manual transaxle's are 3.7. Push button single range, FT4WD single range , the 85-86 RX part time dual range, and the 87-89.5(?) FT4WD dual range. -
All hail the Subaru!!! Best snow vehicle EVER!!!
capn_r replied to skishop69's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Original Rob Where the hell (what the hell?) is PIA? -
1986 GL front and rear diff questions
capn_r replied to hellosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It could also be an 85-86 RX dual range box. 25 spline axle stubs and part time 4WD with the 1.19 low ratio. -
Looking good! When you are you rolling it over the hill for a torque demo?
I looked in my 86 FSM and the only thing I found was a red/blue wire from the check connector II by the wiper motor that went to the ECS light. I hope that helps some. How is your torque monster commuter beater project coming?
Ej25 sohc
capn_r replied to capn_r's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I did get a number off of it (serial # maybe?) by the bellhousing flange B561869 if that means anything to anyone. I will probably pick it up in the next few days and see if I can get any details on it's history. I think it was a take out from a local shop that ended up in the boneyard where I found it. -
Ej25 sohc
The engine is a SOHC, I just don't know how to determine what generation.
